1 - 12 of 12 Posts
Cummin' get ya some!
Here lately ill be driving and the truck just dies for a little while then will run again, also when i go to start it it starts but then it will just rev up and down on its own then just sputter out so then i wait and start it and all runs normal ive been told its my cam sensor but just wanted to hear your guys thoguhts on it. Thanks in advance!!
It sounds like it could be a cam sensor to me, do you have any codes? The cam sensors are now $25 from ford and it only takes about 5 min. to change them so it would probably be worth a try before you do a whole lot of other investigateing
Mod Friendly Title
My truck used to do that... Would die at low speeds/idle or not start sometimes. New CPS and it hasn't done it in a few months.
Dieselis' Maximus
make sure you check you engine oil level first.
97F-3504X4PSD
:usflag Same symptoms my truck had. Mine progressively got worse. New CPS fixed it. Easy change. These guys recommend keeping a spair CPS and a 10mm wrench in your truck.:Thumbup:
Cps
That sounds like what mine did when the cam position sensor was bad last year. I'd be going down the road and all of the sudden I was coasting. Sometimes the tach would go crazy. After I pulled over and turned off the ignition it would restart and be fine, maybe for a couple days.
It's and easy change out, though mine cost about $100. Get an OEM one. The first one I got was from an auto parts store and it was no good.
Mine just did that a few weeks ago until it finally wouldn't start at all. New CPS and it started right up and hasn't had a problem since.
Well i got bored today and decided to cahnge it out cheap easy fix picked one up for $20 for the dealership they also said that it sounds like its going bad well we'll see if that fixes it.
smay665949 said:
the international ones are all I had used untile now that the ford ones have gotten so cheep, because I work for an IH dealer. But I dont think they last any longer than the ones you get from ford.
Dieselis' Maximus
smay665949 said:
Yah all i Bought was the International ones before Ford dropped their prices. However they are the same thing Ford gets them from International.
Discussion Starter #12
well guess that didnt fix it was driving today and the truck died started it and it ran fine again im starting to think its my Edge J/A guess ill run it without it and see what happens
1 - 12 of 12 Posts
