1 - 14 of 14 Posts
Anybody had a problem with there Edge juice. If I have mine on stock the truck runs very smooth. If I turn it up to level 1 or any of the levels for that matter it causes my truck to miss really bad only when feeding fuel to it. If your just cruising down the road it runs fine. As soon as you feed alittle fuel just to mattain speed it starts to miss. If you turn the attitude down to stock it will not do it. Edge said they would check it out but they want everything box ,attitude, wire harness. Just woundering if anyone else has had the same sort of trouble before I rip it all out and send it back.
Typical of Edge... They want to be sure its not the wiring or anything so they want it all back... I had to do the same for my Edge Comp...
It's not your fuel pressure dropping to low is it? You truck will cut out for sure if it isn't getting fuel.
What is a good fuel pressure? If the truck is stock isnt it around 5 to 7 psi. I hear alot of people saying not to let it go below 10psi or you will damage the pump. The stock lift pump does not put out that much. I have a BD lift pump and my fuel pressure at an idle is around 18psi and when I driving down the road at a normal cruising speed it is about 14 to 16psi. If I get in to it it will drop to 8 to 10psi, but when it does this miss thing the fuel pressure is around 12 to 16psi. So I'm very confused because it doesnt do it all the time.
Right out of Dodge/Cummins Factory Service Manuals...
Minimum lift pump pressure is 10 PSI @ WOT
My fuel system...
http://mopar.mopar1973man.com/2002 Dodge/BOMBS/vulcan big line/vulcan_big_line.htm
My fuel pump...
http://mopar.mopar1973man.com/2002 Dodge/BOMBS/campaign pump/campaign_pump.htm
I am able to keep above 10 PSI without any problems up to 380 HP... :poke:
What Year is your truck and How many miles are on it? I ahve a 2000 Dodge 2500 with 139,000 miles and when I installed my edge it shutters when the torque Converter try to lock up or when you are driving and Start to give it gas it will start to hick up and shake.... Everything I have found it sounds like we are having Tranny issues.
Mine is an 01 5 speed with about 96,000 miles. I been paying really close attention to the fuel pressure and it will do this miss anywhere from 10 to 15 16 psi. If I have it on 0 it will not do it even at wot going up hill towing a 7x14 box trailer,fuel pressure the same as above anywhere from 10 to 15 16. If I am going up the same hill doing the same thing if I reach up and turn it to 1 it will miss and buck like crazy. While it's doing that if I turn it back down to 0 it will stop missing immediately. Another thing I've been noticing is that if I have it on 0 and turn it up to 1 while driving I get a little surge of power which I think is normal, but if I go from 1 to any other level up from one I dont get any surge at all. It seams like all the other levels dont do anything. I am not sure if you can feel the diference in power levels or not I dont know anyone else who has the edge juice to compare it with.
did you tap the vp 44? if so try removing that and seeing what happens..
I did tap it I will try removing it in the next couple of days and see what happens.
I was playing with the truck today and noticed that my miss doesnt happen on level 0 I know alot of people say its fuel pressure, But I have the hot level(6) and it runs perfectly on that level also. I pretty sure its the box because if it was fuel pressure or the injecton pump it should be the worst on the hot level at wot. I wish edge would send my call tag so I can get it to them.
Same problem on 2004 auto
hey springer, did you ever solved the problem with the edge? I'm having the same problem with a 2004. I just installed the edge and the power is there but cruising is really bad! I only runs perfect in stock mode!
Discussion Starter #13
I'm not sure what your outside temp is right now,but I have an edge juice w/att and if it's below 40 degrees outside I get the surge that you are talking about. I have sent it back to edge but that did nothing they also told me to clean all connection and make sure to clean the plug located on the driversside firewall are these are the plugs for the injectors I quess. I cleaned everything but I dont think it helped. The only thing that makes mine do it is the temp outside. If I tuen it down to 0 it goes away as soon aas you turn it to 1 or an other number it starts to surge. Hope this gives ya something to go on.
Then its a Edge problem.
Because if it was a stock wiring issues you would still feel the surging after you remove or shut off the Edge Juice...
1 - 14 of 14 Posts
