2008–2010 Ford F-250 with 6.4L Powerstroke
The Ford F-250 with 6.4L Powerstroke engine is an awesome truck with a lot of potential. Many people like to use them as work trucks, and others like to build them for racing. Unfortunately, the factory cooling system isn’t always up to the task when pushing these trucks to the limits. The engineers at Mishimoto recognized this issue and began working on a solution to help solve your cooling concerns. The result was the Mishimoto Aluminum Radiator.
The Mishimoto Aluminum Radiator requires no modification and is a direct fit into the F-250. It even comes with factory-style and CNC-machined, quick-disconnect fittings that work perfectly with the factory coolant hoses. The radiator was also designed with all-aluminum end tanks that are TIG welded to the brazed aluminum core, for durability and longevity.
Whether you are driving your truck to work, hauling a heavy load, or at a race, this radiator will keep your truck cool and reliable. Like all Mishimoto products, this radiator comes with a lifetime warranty to give you that extra piece of mind. So don’t have any more headaches or worries about the factory radiator leaking, and upgrade to the Mishimoto Aluminum Radiator.
Key Features and Benefits:
  • Direct fit
  • 100% brazed aluminum
  • CNC-machined quick-disconnect inlet and outlet
  • Lifetime warranty
For more information on this radiator, check out the product page.
http://www.mishimoto.com/ford-6-4l-powerstroke-aluminum-radiator-08-10.html
