I have been reading about no-lockup converter. I have a 92 IH bus with 7.3 and AT 545 trans. Do I need to change trans or am I OK for cross country trips with the AT545? :shrug:
The AT 545 is a SAE# 3 bellhousing. What other SAE#3 trans would work?
:thanks:
lot's and lot's of 545 tranny's going up and down the road. cheap to fix, and easy to find a replacement for. they may not be the best performers, but they are fairly solid tranny's. service it out, and hit the road!
Super Moderator
The AT545 does indeed use an SAE #3 housing, but the 7.3L has a #2 to #3 adapter bolted between the FW housing and the trans, so you *can* use a MT 643 with their #2 SAE housing.
The AT is a durable trans, and IMO you should NOT spend the major $$$$$$$$$$$ to change it for a different trans for any reason, especially for a lock-up converter, it's simply not worth it, not at all.
John_G do I understand you right that International use an adapter plate on the Motor mount to go from a #2 to the #3 Trans. I have not look that close for an adapter. The one thing for changing trans was some of the #2 trans had overdrive with more gears (6 speed) and were set up more so for a RV use.
Thanks for this information on the housing.
Super Moderator
Yes, most do step from a #2 to a #3.
As I recall, all DTs have a #2 standard, and a #2 to #3 adapter to step down if needed. I *think* a SAE #1 is optional with the DTs as well, but possibally only in the larger truck models.
The V-8s all had #2 FW housings as far as I know, with adapters obviously, if needed.
