1 - 12 of 12 Posts
Hi guys,
I just want to get your thoughts about putting a plow on my truck.
I have a 2006 2500HD duramax ext. cab with a short bed. I would like to put a 8.6 ft western MVP plow on my truck.
What kind of upgrades should i put on the truck to handle the plow?
See if anyone else has done this and what do they think?
Thanks for your help
CRAZY CANUCK
truckn'
From what i have heard/seen, IFS is the worse suspension for holding the weight of plows...
CRAZY CANUCK
Hence the reason i suggested the upgrades, its entirely possible to plow with an IFS, has been done and will continue to be done:rock
i would look into Cognito steering parts
one of their tie-rod kits, the pitman/idler kit and the upper control arm kit..
just preventative measures to keep things together
http://cognitomotorsports.com/store/GM_8-Lug.html
X2 just some basic beef up parts needed. A more budget friendly route IMO would be tie rod sleeves. The braces would be great insurance but may not be needed. I would pass on the upper control arms if your planning to keep it at about stock height. The control arms are to mainly correct the upper ball joint angles on trucks with leveling kits. Also depending on the weight of the plow, if your stock torsion bar keys can't adjust the height enough to set the truck back to stock height with the plow on then green keys may be needed.
Reactions: BriteWhiteRam
CRAZY CANUCK
Thanks Chris, i know that i only want sleeves, but i really dont know much about suspensions, thanks for straightening me out :thumbsup
Cummins Tower
tie rod end stiffners and timbren front bump stops
truckn'
well the only place ive seen and really noticed plows was in michigan, and well, we all know how ghetto faboulus some of those folks are when it comes to doing things right...:fan
a few turns of the torsion bar, sleeves and some counter weight and you will be fine.
Powered By Ford
My brother in law plows with his dmax, stock everything it handles it just fine. no upgrades needed, if your front end is turned way down crank it up, thats about it.
1 - 12 of 12 Posts
