New Product - now taking preorders!
Just released - the all new Quadzilla 1998.5-2002 and 6.7L Dodge Boost Foolers!
Announcing the highly anticipated release of the Dodge Boost Foolers for the 6.7L and 1998 -2002 Dodge 5.9L engines! With the huge success of the original 5.9L Dodge Boost Fooler, and more than 10,000 units in service, it was just a matter of time before we released ones for ALL of the electronically controlled Cummins!
Whether you are towing heavy loads, using a downloader/programmer, or just running modified injectors, the Quadzilla Boost Fooler is a MUST HAVE! With increased psi levels and horsepower levels, and lower EGTs, along with being 100% weatherproof, the Quadzilla Boost Fooler is the perfect way to increase your turbo boost without setting any ECU codes! And if you have a 6.7L, you will see the best gains ever with the Quadzilla Boost Fooler
On any year model Dodge, you will see and be able to:
• Make as much turbo boost as possible with your fueling modifications. Note: some stock turbos do have some limitations.
• Horsepower gains from 10hp on a stock truck and up to 50hp on heavily modified trucks.
• EGT reductions from 75°F on a stock truck and up to 300°F on heavily modified trucks.
The Quadzilla Boost Fooler isn't just all fun, it can also help increase the life of your engine by lowering peak exhaust temperatures while also giving you a small boost in power to go with it!
The Quadzilla Boost Fooler will be shipping on or before March 5th.
Part Number: Application: Retail (Free shipping)
DBSTF98 1998.5-2000 Dodge 5.9L Boost Fooler $79.99
DBSTF01 2001 Dodge 5.9L Boost Fooler $79.99
DBSTF02 2002 Dodge 5.9L Boost Fooler $79.99
DBSTF67L 2007.5-2009 6.7L Boost Fooler $119.99
