I'm looking at getting the Quadzilla Boost fooler but I have a few questsions. First a little info about my truck. I have an 06 and a BD with the Crazy Larry tune. I have an aftermarket intake and will be installing a new exhaust soon.
Does is really work?
What should I expect to gain performance wise?
Effect on EGT's?
I do not have head studs, should I worry about that? Head gasket problems?
Do I need to worry about valve springs?
Anything else I should know or be concerned with?
Thanks in advance for your input.
WANNA SMOKE!!!
If you just have the Crazy Larry, Intake, and Exhaust you wont have anything to worry about. I was running that same set up but when i stacked the edge then i was hitting 42-45 lbs. of Boost which is ok but i wouldnt get over that bc then you have to worry about head gaskets and studs. It does truly work. Although the Edge has one built into it, i tried a buddies when i just had the Crazy Larry and it gave me 4 more lbs. No need to worry about valve springs. How much smoke are getting?
Hey it does work, you might gaing about 40-50 HP out of it but it will help keep EGT's in control. I was running one with my CL before i switched to the smarty, now i dont need the fooler anymore, if you need it, ill sell it to you. PM me if you are interested.
When i had it i could hit 45 psi. Nothing to worry about. I ran at 50 psi all day and never had a problem with the stock head bolts.
Discussion Starter · #4 ·
It smokes pretty decent on crazy larry when I go to WOT. It's pretty cool! I definitely leave a cloud behind me but once my RPM's come up the smoke stops.
the smoke stops cuz your boost goes up and you have enough air to burn off the excess fuel.
WANNA SMOKE!!!
Listen to Bill. HE'S THE 7sec MAN!!!!
LMAO....:nitrous:
Its Cute Aint it!!
SMARTY!!!!!!!!:smoke
