Hi. I just bought an early 99 PSD CC w/ 203k miles. I've read a lot of the sites, including spending 2 days reading the threads on this site, and haven't yet seen the response to this question -
What is tha advantage of a turbocharger vs. a supercharger in the 7.3 DI application?
Thanks for your responses - I'm sure I'll learn a lot...
Supercharger has "parasitic" Hp Loss. A turbo is using "free" power to build boost.
I wouldn't say it's "free." You have a loss of hp due to exhuast back pressure.
Comparatively speaking it is free...Depending on the turbo set-up and IC set-up it can be a 1 to 1 ratio... 40# back pressure for 35-40#'s boost...
On the other hand there is turbo lag while the pressure builds where a supercharger adds boost with an increase in engine rpm.
Super Moderator
The turbo is the most efficient form of forced induction short of the Axial Flow Supercharger (ala Jet engine). You get the most FLOW for a given HP input and the least increase in air temp.
At best, a turbo is about 72% efficient, that is very far from "free" power but much better than the 50% efficiency of a Roots/hEaton style blower.
Blowers will give you the great off-idle Tq like a N/A engine can, but cannot supply the coolish air at the upper RPMs like a turbo (or AFSC).
It's all about the goals. That is why the 6.0L/6.4L have VGTs, it allows a medium-large turbo to flow a lot of air at low enigne RPMs (like a small turbo), but not over-speed at the higher RPMs like a small turbo and still flow the amount of air that is needed to make very good power.
