My PCM has gone bad and I have found one at a good price but not sure if it will interchage. I have a F350 4dr dually with 7.3l and the one I have found is for a 96 F350 4dr dually with the 460 in it. My question is can I use this with my powerchip and it will override the flash in the PCM?
My PCM
F5TF-12A650-BJF TEE5
The other one
F6TF-12A650-AMD FEZ3
FRANKEN STROKE
Diesels and Gasssers dont uslley mix so I would have to say no, but I would call a dealer to find out for sure! Or just contact DP Tunner! He will know if your chip will fix it!
No it will not work. You will need to replace with a like designation of your PCM.
Thanks for the reply's I will see if the dealer has one in the morning, I will also check this dp. do they have a website ?
Slottech
Thank you for the info :usflag 1040 WreckerMan.:usflag
it looks like I can buy the 1 I was talking about and flash it to mine and save$$$
