How and where do I install this (http://www.ebay.com/itm/TANK-TYPE-EN...-/110794144143) ? I am concerned about putting it in a place that will actually circulate the coolant and not install it somewhere it is deadheaded. I know the heater hoses run into the water pump, but will it circulate through it like a bypass or will it not?
Aimless Wanderer
Try to place it as low on the frame or engine mouting bracket as possible. As the temperature rises from the heating elements a natural pumping/flow will take place due to expansion. I like to go straight into the return line from the heater core myself.
Would that be the line on the drivers side of the heater core?
Aimless Wanderer
I can't tell you that myself as I'm unfamiliar with the layout. Usually the inlet line to a heater core has a water cutoff valve installed, the return does not.
