Hey guys,
I got a quick question I am suppose to visit the Fam in Columbus this week for thanksgiving…I recently purchased Innovatives extreme street tune, I am suppose to be getting gauges from x mas so I don’t have them yet. I realize that I should and I will come Christmas but I just don’t have them yet:pointlaugh . anyways my question is will I be ok to drive my truck with the extreme street tune in it?all highway miles(I90) prob top speed 72.( its going to be roughly 6 hr trip) or should I turn it back to stock for my trip? don't really care if I turn it back to stock just wanted the better mileage.
Kris
Yes you will be fine. I just got my Extreme Street tune from Eric 2 weeks ago and talked to him for a couple of minutes because I dont have a egt gauge yet either. He said that I would be fine under normal driving and could even make some runs from 0 to 70ish with no problems but not to go and run a 1/4 mile before I get the exhaust on and my gauge. Go to it and enjoy.
Hi, my name is Trebron I own a 2005 Ford Excursion 4x4 6.0 turbo diesel.A diesel
machanic informed me if I what to increase my M.P.G. not to add the intake
system , exhaust and power programmer. But all I read is that it will improve
the M.P.G. and add horse power if I do add the following parts. I what to
improve my M.P.G. what can I do and what parts do you recommend? Please help.
Thank you.
Trebron ([email protected])
Little bit of a thread hijack, but let's see if I can answer both questons.
I would go without the gauges:
I have ID's extreme street tune and a gauge. For normal driving at 70 mph, including long climbs, the temperatures stay well below 1200F. For normal wide open passes on 2 lane roads, there should be no problems with temperature either. Temps may exceed 1200, but this is a brief period.
Here is one reason a reprogrammed/chipped vehicle may get better mileage:
I am getting better mileage (~1 mpg) with my SCT tune. I believe this is because the tune shuts off the EGR. My old Edge had a lot of power, but didn't shut off the EGR. I saw no changes in mileage when I installed the Edge.
My mpg went up with all my mods.......as long as I can keep my foot out of the giggle peddle.
With what ever you do, if you can keep your cruising rpm at or below 2000 your milage will be better.
Drive sensible and you will be more then fine as long as your not towing big stuff up big hills.....
Thanks guys,
That’s what I figured. once I get out of the CNY area its pretty flat. I am looking forward to getting my gauges, just so there isn’t any mystery what’s going on.
kris
reply
I have an 02PSD. Gauges on the APillar. The two biggest things that I and my son changed that helped the mpg was to get rid of the factor air filter intake and install one with more access to air and to eliminate the factory installed muffler. Now have a flow through. Fuel mileage went up about 4mpg with just these two changes. The next was a DP Tuner by Jodi. First pull out, with a 30' fiver was around 19.5mpg. Not bad as I only was getting around 12 before.
Obviously Intuitive !
I had to chose between gauges and exhaust when I first got my tuner...
since gauges only tell me there is a problem and exhaust lessens the chance of a problem, I went with exhaust first....
and that was on my 03 Ex that I never put gauges on....
yes, yes, yes, it's nice to have gauges, but since most here have done all the measurements and I rarely tow, I first helped the flow by removing the stock boat anchor of a muffler for a better flow thru one like the Walker BTM...
would have prefered a turbo bak like I put on the 03 , but the 05 seems to lke the BTM and SCT combo...
