1ftww31p35ea94942
TIA
OASIS RESULT:
1FTWW31P35EA94942
09/08/2006
20:32:33
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
10/20/2004 BUILD DATE
10/06/2004 SALE MILEAGE
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-17-06
BEFORE ADDRESSING VEHICLE VIBRATION CONCERNS, SEE TSB 05-26-24
WARNING MESSAGES
05B32
DE-GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
07/24/2006
DEALER: Thornhill Ford-Mercury
WARRANTY CLAIM NUMBER: 076604 ODOMETER: 080623M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 002 VERIFY60 42 DOES NOT OPERATE PROPERLY
VC 7B 002 6005F
000 6005F1
000 6005F1X1
000 6005F2
000 6005F6
000 6005F8
000 6005F9
000 6005F11
000 6005F12
000 6005F13
000 6005F14
000 6005F18
000 6005F19
000 6005F20
000 6005F21
000 6005F22
000 6005F23
000 6005F33
000 9527AT
VERFIED CONCERN PERFORMED DIAG PERFOMRED INJECOTR ISOLATOR TEST REPLACED #2 AND #3 INJECTORREASSEMBLED AND RETESTED L OK
07/17/2006
DEALER: Performance Ford
WARRANTY CLAIM NUMBER: 019337 ODOMETER: 080431M
LABOR OP
CONDITION CODE
CONDITION DESC
OSP 001 6005F
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 001 6005F13
3C3Z 9T517AE KIT-REG FUEL PRESS 001 6005F1
3C3Z 9C407AB PUMP&ISOLATOR-FUEL E 001 6005F2
000 6005F1X1
000 6005F14
000 6005F20
000 6005F11
000 6005F18
000 6005F19
000 6005F21
000 9527AL
000 MT9527
000 9517A
000 9350E
DEFECTIVE INJECTORS VERIFY CONCERN,DIESEL ENG.PERF.DIAG.MONITOR BALANCE 8 ,6,4, MISS AT START UP,#2 DROPS OUT IN A FEW MIN.THEN TRUCK DIES CHECK FUEL SYSTEM,AFTER RUNNING A FEW MINS. FUEL STARTS BOIL ING AND GIVES OFF EXHAUST, ANOTHER INJ. LEAKING THROUGH CENTER,REPLACED INJ. 8 & 6, RETEST. # 4 STIIL D ROPS AFTER ROAD TEST AND FUEL PRESSURE DROPS TO 36 PSI,REPLACED #4 INJ.REGUL
06/29/2006
WARRANTY CLAIM NUMBER: 076076 ODOMETER: 078534M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F838A SENSR ASY F/I TIMING 001 6005F 42 DOES NOT OPERATE PROPERLY
5C3Z 12224A 3 WAY VACUUM CONNECT 001 6005F1
000 6005F1X1
000 6005F2
000 6005F6
000 6005F8
000 6005F9
000 6005F11
000 6005F12
000 6005F13
000 6005F14
000 6005F18
000 6005F20
000 6005F21
000 6005F22
000 6005F23
000 6005F33
000 VERIFY60
000 9838A
000 14200A
000 12650D84
PERFORMED ALL DIAG REPLACED ICP SENSOR AND RETESTED ALL OK
02/17/2006
WARRANTY CLAIM NUMBER: 072921 ODOMETER: 058881M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 9G282AA PMP & FLTR ASY-FUL 001 9350E 42 DOES NOT OPERATE PROPERLY
6C3Z 9F759A WIRE ASY FUEL VAPOR 001 MT9F452
4C3Z 9F452A TRANSDCR-EGR BACK PR 001
REPLACED FUEL PUMP
02/17/2006
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9J460A SENSOR ASY EGR PR VL 001 05E15M
RECALL COMPLETED
02/17/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
RECALL COMPLETED
08/22/2005
WARRANTY CLAIM NUMBER: 068638 ODOMETER: 035992M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 19980BB CONTROL A/C 001 12651D2 42 DOES NOT OPERATE PROPERLY
000 19980A
PERFORMED ELECTRICAL DIAG RPELACED ATC HEAD RETESTED AC OPERATES PROPERLY
08/22/2005
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 2C286AA CONTR ASY-BRK ANTI/L 001 2219D 42 DOES NOT OPERATE PROPERLY
000 2219D11
TESTED BRAKE SYSTEM FOUND HYDROLIC CONTROL UNIT BAD REPLACED ALL OK
08/22/2005
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F1X1
000 6005F2
000 6005F6
000 6005F8
000 6005F9
000 6005F11
000 6005F12
000 6005F13
000 6005F14
000 6005F18
000 6005F20
000 6005F21
000 6005F22
000 6005F23
000 VERIFY60
000 12650D84
000 MT9F452
PERFORMED DIESEL DIAG RPELACED EGR VALVE AND RE PROGRAMMED PCM TCM AND FICM RETESTED ALL OK
END OF OASIS REPORT FOR 1FTWW31P35EA94942
