1 - 10 of 10 Posts
Nitro Lab Rat
I am looking to change out the stock exhaust to something that will let the truck breath, but I have to keep the noise and drone levels to a minimum to please mamma and the kids on the long trips. I would prefer turbo back but will consider cat back. Any suggestions?
Diesel Pro
do an aftermarket preferably 4" turbo back mbrp, get ridda the kitty and keep the muffler on it that it came with :) and get a 6" tip, skip the 5" tip, and get the 6" WAY COOLER! :)
when normally recomend a turbo back magnaflow when you want it quiet and keep the cat wil help with drone.
I just put on a Aeroturbine before the holidays. 3 1/2 in and out. Truck seems to like it. Sounds just a tad louder than stock but not offensive. Picked up a little fuel mileage also. It is the model with the resonator. :Thumbup: :usflag
Nitro Lab Rat
Do you have a wav file of how it sounds inside the cab you can send me?
Diesel Pro
its not much louder than stock going down the road cruising, hardly notice a difference at all till you get on it and it downshifts and revs to 4k, and it is louder at idle, but no where near as loud as being straight piped. i have some vids on youtube of the truck outside revving
I've been considering the Corsa Cat-back exhaust because they claim to eliminate the drone and drop the cruising decibels. It is a more expensive unit though, but I'd still check it out.
I have a muffler delete pipe, and its not bad, as long as your foot is not deep in the throttle, I still have the cat in there, the turbo helps with the sound. Im sure that you will behappy witch ever system you choose. Keep in mind the delete pipe cost less than $50 installed, and is easy to remove. Good Luck!
Nitro Lab Rat
Thanks all. I think I'll go with a MBRP 4" turbo back system keeping the kitty, muffler and my wife.
1 - 10 of 10 Posts
