1 - 10 of 10 Posts
CRAZY CANUCK
when sitting idling angle parked on a street, rad fluid will dump out of the overflow excessively, what would cause excess pressure to build up in the rad and dump rad fluid over the overflow??? only happens at idle, and there is not too much fluid in the degas bottle.... help? :bang
CRAZY CANUCK
Nope engine runs perfectly normal temp, that's what's bothering me, usually your temp fluctuates if its head gaskets doesn't it?? I will try washing the cap to see if that helps, thanks
CRAZY CANUCK
Did you have any other symptoms other than rad fluid blowing out the overflow?
CRAZY CANUCK
CRAZY CANUCK
Discussion Starter #8 (Edited)
not at all what i wanted to hear :damnit
Did you happen to notice your oil being creamy/frothy at all?
CRAZY CANUCK
upper rad hose was still hard this morning after sitting all night... pressure never bled off at all last night? bad rad cap?
1 - 10 of 10 Posts
