1 - 20 of 21 Posts
Mod Friendly Title
Here's the deal. I've been getting a random vibration from my front end lately. Not all of the time, but just out of the blue it will start to vibrate. Only really noticeable on the highway. It isn't the roads. Don't think its the front tires, they were just balanced 5K? miles ago, plus, like I said, it is a random vibration. :damnit
Also, factory ball joints didn't have grease fittings, right?
TDG MAFIA #101
Factory ball joints as well as some of the after market ones didn't come with grease fittings. And my truck will vibrate at speeds between 35-45 mph. I still haven't figured out what it is, I haven't found anything loose in the front end though. Maybe someone will help the both of us mid-missouri boys.
Mod Friendly Title
Discussion Starter · #3 ·
Ok, all of my ball joints have grease fittings.
Anyone have suggestions as to what it could be?
Mod Friendly Title
Discussion Starter · #4 ·
Bump. Anyone? Tie rods? Drag link? :shrug:
MAFIA MEMBER 106
can you feel it in the wheel i assume you have jack it up and checked the tire play top and bottom and right lefr?
Mod Friendly Title
Discussion Starter · #6 ·
Can't really feel it so much in the wheel... More of the whole front end.
TDG MAFIA #101
Steering Wheel?? I can feel my vibration in the steering wheel, and my wheels and tires seem to be stout, so I don't think its the ball joints.
Mod Friendly Title
Discussion Starter · #8 ·
Yeah... Don't feel it in the steering wheel, but my steering box does feel like it needs to be tightened up a hair...
TDG MAFIA #101
Could that be whats wrong with mine, cuz I feel it bad in the steering wheel.
Mod Friendly Title
Discussion Starter · #10 ·
Ok, so I can feel it in the steering wheel. Yesterday I got to taking a look at the front end. My steering stabilizer is bent badly... :damnit Could this be causing all of the problems??
Mod Friendly Title
Discussion Starter · #11 ·
strokin now cummin later!
highly dout its the stabilizer. i bet both of you need new wheel hubs on the front end. i would almost bet money on it. by 90k i had already had both of mine replaced. i was feeling a vibration here and there. the other one felt like a little thumping on the floor board.
Mod Friendly Title
Discussion Starter · #13 ·
The hubs are new...
TDG Single Club Member#14
The steering wheel vibration on mine was coming from the joint where the pitman arm is. With the truck off have someone jerk the wheel as far as you can back and forth and you'll see the movement.
MAFIA MEMBER 106
could also be trac bar bushings?
did u change the air in your tires from summer air to winter air?LOL LOL LOL
Mod Friendly Title
Discussion Starter · #17 ·
They were rebalanced in September when I got new rear tires...
Dually Club member #56
If your stabilazer is bent, it very well could be bad. And may need replaced anywaya.
:believe LOL
have u check to see it all the nuts and bolts were tight? also what about you bushings, how do they look.
Mod Friendly Title
Discussion Starter · #20 ·
orangepstroke said:
:believe LOL
What bolts and what bushing? There's lots of em... :poke: LOL
1 - 20 of 21 Posts
