1 - 13 of 13 Posts
Installed Readylift 3.5" SST hybrid leveling/lift kit radius arm drop, etc
Sitting on 37x13.50x20 Toyo Open Country M/Ts with Helo 837 20x9" wheels
Here are some pics
Before
After
Looks good. Tires must be really close to the corner of the fendar when you turn. I like those wheels
They are close but not that bad doesn't rub at all on radius arms. Good to go!
No I looked and thought it would work but decided to let them hang for now bc if wheels drop in a hole it would prob pull them off
Reactions: TEN2THREE
Green Goose No Juice
Good looking truck
Dunno ill measure when I get time. Fits in garage but just bc I've got 8' doors
Is that the one for 300 and something? I been looking at that one if thats the one.. I think you just helped me buy it if it is
Nevermind im thinking about the 2.5" lift.. sorry
Discussion Starter #12
yeah this one is the $799 kit, i picked it up CHEAP on ebay only reason i decided to try it if not woulda went with the BDS 4" or something
Discussion Starter #13
had truck aligned today b/c pulling to the right some, everything up front is in check but still pulling to the right, they said it was b/c the rear end was shifted forward or something like that, most ppl ive seen with blocks it shifts rearward, going to pull off and reinstall the blocks and see if i got them off somehow, only thing that centers them are the studs sticking out so doubt thats the reason,
never did it pull any direction before the lift install
swapped wheels around in the front from side to side and still pulls right so not the wheels, might try that on the rear and see if it does anything doubt it though
1 - 13 of 13 Posts
