How difficult is it to remove that pesky kitty? 06 duramax all stock except Line-x bed liner
diesel idiot
sawzall.... about 5 minutes. Id just buy a 4 inch front pipe without a cat... if you wanna keep the stock exhaust on it there are front pipes out there from MBRP and Dynomax that still utilize the four bolt flange so itll bolt right up. They can be had for about $120 from jegs or summit. Also on the newer trucks its likely you will throw a code with no cat and a bigger exhaust.
diesel idiot
I have an 04, and i put a new fornt pipe on mine so i took it out. but if he is just wanting to straight pipe the stock exhaust obviously hed have to cut it.
diesel idiot
are you running anything other than the stock exhaust on your truck KB?
diesel idiot
very nice. i have a dynomax front pipe, and midsection because i got it for really cheap, and then the stack and stuff i put together just with stuff from the pete shop.
