Smokin
Trying to find a good solid vehicle for family to travel accross the states I have a good one possibly picked out just needing the history to make sure family is not in any known harm. I also want to go ahead and Thank you very much for doing this. I known its time out of your day to do this and thanks again.
Randy
1FMSU45P05EA23262
Standard Claims List For Model Year 2005
1FMSU45P05EA23262 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 09-AUG-2004 31-AUG-2004 152146 USA 1 6C06 010507 * 5431012 * N59 33 255
AWS Claim Key: 85041 Trx Code: 2 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 07670 - * Name: MAC HAIK FORD LINCOLN MERCURY Ph: 512-9303673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:27-SEP-2004 Doc #:201181A
Cust Comments: N59,CHECK FOR SQUEAK FROM RT REAR OF VEHICLE,VERIFIED BY ADVISOR
Tech Comments: 255 CC33 RIGHT QUARTER PANEL SQUEAKS. R&I TRIM PANEL INSTALLED ROTUNDA ADHESIVE FUZZY TAPE ON CLIPS.INSTALLED BACK IN PLACE TEST PASS. #27840
1FMSU45P05EA23262 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 09-AUG-2004 31-AUG-2004 152146 USA 13 7S12 180102 * 14A200 * E29 X2 26271
AWS Claim Key: 1984791 Trx Code: E83 Labor Hrs: 3.7
Dlr Cd-Sub Cd: 07670 - * Name: MAC HAIK FORD LINCOLN MERCURY Ph: 512-9303673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:22-SEP-2005 Doc #:226756C
Cust Comments: E29 CUST.STATES CHECK ENGINE LIGHT IS ON
Tech Comments: 26271 CONNETION POOR X2 PERF DIG 1 7 AND 10A 10B 10C AND 11 CODES P0231 P0266 ELETRCAL TEST POWER TO FUEL PUMP NO POWER FUSE CHECK OK FUEL PUMP RELAY OK CHECK POWER AT FUEL SHUT OFF SWITCH OK WIGGLE TEST CONNECTOR 282 BAD CONNETION REPAIR CONNETION RETEST OK
1FMSU45P05EA23262 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 09-AUG-2004 31-AUG-2004 152146 USA 24 * * * * * * * 47227
AWS Claim Key: 5475220 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07670 - * Name: MAC HAIK FORD LINCOLN MERCURY Ph: 512-9303673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:01-AUG-2006 Doc #:249106E
Cust Comments: OWNER NOTIFICATION RECALL,59B01 ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIONS RECALL 05E15 OR 06E17 FOR DETAILS
Tech Comments: 47229 59B01A 030 ROAD TEST OK
AWS Claim Key: 5475219 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 07670 - * Name: MAC HAIK FORD LINCOLN MERCURY Ph: 512-9303673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:01-AUG-2006 Doc #:249106D
Cust Comments: OWNER NOTIFICATION RECALL, 05E15 EXHAUST PRESSURE SENSOR REPLACEMENT, ON BOARD DIAGNOSTIC SYSTEM AND ENGINE CONTR OL MODULES RECALIBRATION
Tech Comments: 47229 05E15M 100 R AND R EBP SENSOR REPROGRAM
1FMSU45P05EA23262 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 09-AUG-2004 31-AUG-2004 152146 USA 24 1H03 030008 4C3Z 9F452 A D42 69 47227
AWS Claim Key: 5475218 Trx Code: S07 Labor Hrs: 4.6
Dlr Cd-Sub Cd: 07670 - * Name: MAC HAIK FORD LINCOLN MERCURY Ph: 512-9303673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:01-AUG-2006 Doc #:249106A
Cust Comments: D50 ENGINE STARTS BUT LACKS POWER, CHECK AND ADVISE
Tech Comments: 47229 9F452 69 PERF DIG 1 13 CODE P0404 PID MONMITOR EGR VALVE ACTIVE COMMAND EGR VALVE NO CHANGE ENGINE SOUND R AND I EGR VALVE AND INSPECT FOUND CARBON CONTAMINATION VALVE STUCK OPEN R AND R EGR VLAVE CLEAN EGR PORT ROAD TEST RTEST OK
