VIN: 1FTSW21P25ED02009
Thanks
Standard Claims List For Model Year 2005
1FTSW21P25ED02009 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2005 26-APR-2005 171089 USA 21 * * * * * * * 30264
AWS Claim Key: 6889304 Trx Code: 05E16 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07946 - * Name: KEN GRODY FORD Ph: 714-5213305 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:10-JAN-2007 Doc #:06232540
Cust Comments: 05E16 ENGINE CONTROL MODULES RECALIBRATION
Tech Comments: RECALL MODULE RECALIBRATION
AWS Claim Key: 6889305 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 07946 - * Name: KEN GRODY FORD Ph: 714-5213305 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:10-JAN-2007 Doc #:06232541
Cust Comments: 05B32 DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
Tech Comments: RECALL COOLANT DEGAS BOTTLE LABEL INSTALLATION AND COOLANT LEVEL AD
1FTSW21P25ED02009 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2005 26-APR-2005 171089 USA 22 7X01 011000 YC3Z 7861711 AA S06 42 31110
AWS Claim Key: 7149492 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: 07946 - * Name: KEN GRODY FORD Ph: 714-5213305 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:07-FEB-2007 Doc #:06438251
Cust Comments: USE SPO 07010021 SEAT TRACK ORDERED ON R.O. 62326, PRESTIGE UPH TO INSTALL SEAT TRACK
Tech Comments: SEAT TRACK INOP, SUBLET FOR REPLACEMENT
1FTSW21P25ED02009 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2005 26-APR-2005 171089 USA 23 6E01 0110XX 2C3Z 25632A23 AA S50 D4 32606
AWS Claim Key: 7345944 Trx Code: E84 Labor Hrs: 0
Dlr Cd-Sub Cd: 07946 - * Name: KEN GRODY FORD Ph: 714-5213305 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:19-FEB-2007 Doc #:06517351
Cust Comments: C S: DRIVERS SEAT CUSHION IS BREAKING DOWN ON OUTSIDE PART OF SEAT
Tech Comments: SUBLET FOR SEAT CUSHION REPLACEMENT
1FTSW21P25ED02009 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2005 26-APR-2005 171089 USA 42 2E01 030008 4C3Z 9F838 A D42 42 54866
AWS Claim Key: 10373955 Trx Code: S07 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 07946 - * Name: KEN GRODY FORD Ph: 714-5213305 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:10-SEP-2008 Doc #:00715951
Cust Comments: CUSTOMER STATES VEHICLE ONCE WORM WILL HESSITATE TO EXCELERATE LACK POWER RPMS WILL BEGIN TO SURGE AFTER A FEW SECONDS VEHICLE WILL GO BACK TO NORMAL. CUSTOMER STATES WHEN AT STOP LIGHT VE
Tech Comments: ICP SENSOR OUT OF RANGE 120PSI, CONNECTOR DAMAGED HARD START NO START DIAGNOSTICS DIESEL ENGINE DIAGNOSIS, REPL ICP SENSOR, RETEST
1FTSW21P25ED02009 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2005 26-APR-2005 171089 USA 42 6Y20 000000 * TAP1 * A99 82 54866
AWS Claim Key: 10425138 Trx Code: TAP1 Labor Hrs: 0
Dlr Cd-Sub Cd: 07946 - * Name: KEN GRODY FORD Ph: 714-5213305 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:10-SEP-2008 Doc #:00721851
Cust Comments: TAP DAY RENTAL
Tech Comments: REF RO 07159, HERTZ INV A18244413
1FTSW21P25ED02009 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2005 26-APR-2005 171089 USA 58 2E01 030403 4C3Z 9F838 A D02 42 72708
AWS Claim Key: 11372575 Trx Code: S07 Labor Hrs: 12.1
Dlr Cd-Sub Cd: 00751 - * Name: DAVID WILSON'S FORD OF ORANGE Ph: 714-9781850 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:11-JAN-2010 Doc #:03976651
Cust Comments: CUST STATES VEH TAKES 4 5 SECONDS TO START
Tech Comments: CK ENG PERFORMANCE TEST KOEO DOEO ELECTRIC INJ TEST ICP AND IPR TEST LOW CRANK ICP 425 PSI AND IPR 84% INSPECT IPR AND FIND MISSING SCREEN AND STILL LONG CRANK AND WHEN VEHICLE IS HOT NO START PERF LEAK TEST REMOVE VALVE COVERS TO PERF THE TESTS SOME AIR FROM OIL PRESS RAILS PLUGS AND STC FITTING KIT REMOVE AND ISNTALL INJ PUMP TO INSTALL STC BRACKET KIT REPL ICP SENSOR LEAKS OIL AND CAC HOSE CRAC
1FTSW21P25ED02009 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2005 26-APR-2005 171089 USA 61 1D01 03XXXX 3C3Z 6710 BA L65 D1 76658
AWS Claim Key: 11468950 Trx Code: E72 Labor Hrs: 15.4
Dlr Cd-Sub Cd: 00751 - * Name: DAVID WILSON'S FORD OF ORANGE Ph: 714-9781850 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:19-APR-2010 Doc #:04282252
Cust Comments: CUST STATES THAT THERE IS A OIL LEAK COMING FROM REAR OF OIL PAN
Tech Comments: VERIFY OIL LEAK AT RIGHT SIDE OF ENG ADD OIL DYE CK W UV LAMP IS LEAKING AT RIGHT ENG BEDPLATE SEAL REMOVE ENG TO PLACE ON ENG STAND REPL BEDPLATE SEALS AND ALL SEALS AND HARDWARE ASSICIATED WITH THIS PROCEDURE AS PER WORKSHOP MANUEL REINSTALL ENG ADD NEW COOLANT AND OIL AND FILTER ROAD TEST AND RECK FOR LEAKS OKAY ADJUST CAC HOSE TO PREVENT HOSE FROM CONTINUING TO BLOW OFF OK AT THIS TIME
1FTSW21P25ED02009 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2005 26-APR-2005 171089 USA 61 2E03 030402 4C3Z 9E527 BRM D36 42 76658
AWS Claim Key: 11472056 Trx Code: S07 Labor Hrs: 3.5
Dlr Cd-Sub Cd: 00751 - * Name: DAVID WILSON'S FORD OF ORANGE Ph: 714-9781850 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:19-APR-2010 Doc #:04282251
Cust Comments: CUST STATES ENG RUNS ROUGH
Tech Comments: VERIFY CUSTOMERS CONCERN ENG MISFIRES COLD CK FICM CALIBRATION IS AT ARZ2ALI AT LATEST CALIBRATION PERF DIESEL ENG PERF DIAG PERF KOEO SELF TEST RETRIEVE CODE P0269 CYL 3 MISFIRE PERF FUEL PRESS TEST AT SECONDARY FUEL FILTER HOUISING AT 56 PSI W VALVE OPEN PASSED PERF PWR BALANCE TET CYL 3 60 RPM PERFORM RELATIVE COMPRESSION PRIOR APPROVAL REPL INJ AT RIGHT BANK CYL 3 COLD START NEXT MOURING ENG R
1FTSW21P25ED02009 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 07-APR-2005 26-APR-2005 171089 USA 62 1B03 030204 3C3Z 6A642 CA E23 55 77464
AWS Claim Key: 11498194 Trx Code: 0968D Labor Hrs: 9.5
Dlr Cd-Sub Cd: 00751 - * Name: DAVID WILSON'S FORD OF ORANGE Ph: 714-9781850 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:24-MAY-2010 Doc #:04385452
Cust Comments: VEH SEEMS TO BE RUNNING A LITTLE WARMER
Tech Comments: VEHICLE CONCNER PERFORM DIESEL PERF DIAG VISUAL LOW COOLANT LEVELS EEC TEST NO DTCS PERF TSB 090803 PRESS TEST COOLING SYSTEM 16 PSI NO EXTERNAL LEAKS BOTTLE CAP OK INSTALL RAD KIT PLUS DOESNT HOLD VACUUM REMOVED EGR COOLR AND BENCH TEST BUBBLES COMING OUT OF COOLER, REPL EGR COOLER AND OIL COOLER PER TSB CHANGED OIL AND FILTER AND FLUSH COOLING SYSTEM ROAD TEST AND RETST OK AT THIS TIME
