Standard Claims List For Model Year 2002
1FTWX33FX2EC72889 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 03-APR-2002 12-JUN-2002 174542 USA 10 2E06 030404 F81Z 9A543 CRM L65 D8 14123
AWS Claim Key: 5288495 Trx Code: S07 Labor Hrs: 2.5
Dlr Cd-Sub Cd: 08621 - * Name: SEEKINS FORD/LINCOLN-MERCURY, INC. Ph: 907-4594000 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:07-APR-2003 Doc #:20685401
Cust Comments: L65 OIL LEAKING FROM REAR OF ENGINE.
Tech Comments: DIAG AND PERFORM DIESEL DIAG AND PERFORMANCE SHEET REPLACED LEAKING HIGH PRESSURE OIL PUMP RE RING FUEL FILTER HOUSING
1FTWX33FX2EC72889 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 03-APR-2002 12-JUN-2002 174542 USA 10 2E06 030404 F81Z 9C387 BA E68 D8 14123
AWS Claim Key: 5327096 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 08621 - * Name: SEEKINS FORD/LINCOLN-MERCURY, INC. Ph: 907-4594000 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:07-APR-2003 Doc #:20685403
Cust Comments: E68 FUEL LEAKING.
Tech Comments: REPLACED O RING AT FUEL FILTER HOUSING NOW OK
1FTWX33FX2EC72889 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 03-APR-2002 12-JUN-2002 174542 USA 18 7F03 011605 2C3Z 17508 AA W05 42 28125
AWS Claim Key: 8079971 Trx Code: E83 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 08621 - * Name: SEEKINS FORD/LINCOLN-MERCURY, INC. Ph: 907-4594000 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:12-NOV-2003 Doc #:22028001
Cust Comments: W05 WIPERS INOP.
Tech Comments: MTIME TO PERFORM MULTIPLE PIN POIN TESTS. REPL WIPER MOTOR
1FTWX33FX2EC72889 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 03-APR-2002 12-JUN-2002 174542 USA 18 7B02 140201 2C3Z 10346 BARM C25 42 28671
AWS Claim Key: 8195281 Trx Code: E83 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 08621 - * Name: SEEKINS FORD/LINCOLN-MERCURY, INC. Ph: 907-4594000 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:18-NOV-2003 Doc #:22066001
Cust Comments: C25 PROBLEM WITH CHARGING SYSTEM ELECTRICAL RAN ON BATTERIES UNTIL ENGINE DIED GIVE EST IF NOT WARRANTY.
Tech Comments: DIAG AND PERFORM ALTERNATOR AND CHARGING SYS TEST REPLACED BAD ALTERNATOR ,RE TEST NOW OK
1FTWX33FX2EC72889 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 03-APR-2002 12-JUN-2002 174542 USA 18 5T01 * * * * * * 28671
AWS Claim Key: 8195280 Trx Code: 03B03 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 08621 - * Name: SEEKINS FORD/LINCOLN-MERCURY, INC. Ph: 907-4594000 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:18-NOV-2003 Doc #:22066002
Cust Comments: PERFORM CUTOMER ATIFACTION PROGRAM 03B03
Tech Comments: AN ELECTRONIC ENOR THAT IS PART OF THE ACCELERATOR PEDAL AEMBLY MAY NOT ALWAYS WORK PROPERLY REPLACE ADJUTABLE ACCELERATOR PEDAL SENSOR AND CLEAR DTC,S PERFORM RECALL 03B03
1FTWX33FX2EC72889 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 03-APR-2002 12-JUN-2002 174542 USA 20 7M01 150102 * 18805 * A16 42 31007
AWS Claim Key: 9158939 Trx Code: E83 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08621 - * Name: SEEKINS FORD/LINCOLN-MERCURY, INC. Ph: 907-4594000 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:09-JAN-2004 Doc #:22343401
Cust Comments: CD PLAYER DOES NOT EJECT CDS
Tech Comments: REMOVED CD PLAYER SENT TO REPAIR STATION PUT RADIO BACK IN NOW OK
1FTWX33FX2EC72889 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 03-APR-2002 12-JUN-2002 174542 USA 20 7D05 170104 3C3Z 15200 BA L29 B5 31007
AWS Claim Key: 9158938 Trx Code: E83 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 08621 - * Name: SEEKINS FORD/LINCOLN-MERCURY, INC. Ph: 907-4594000 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:09-JAN-2004 Doc #:22343402
Cust Comments: FOG LIGHTS HAVE MOISTURE IN THEM
Tech Comments: VERIFIED CONCERN FOG LIGHTS HAVE CONDENSATION MOISTURE IN THEM R AND R FOG LIGHTS VERIFY OPERATION OK
1FTWX33FX2EC72889 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 03-APR-2002 12-JUN-2002 174542 USA 20 5A09 050201 1C3Z 4676 AA L88 D8 31007
AWS Claim Key: 9158937 Trx Code: E84 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 08621 - * Name: SEEKINS FORD/LINCOLN-MERCURY, INC. Ph: 907-4594000 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:09-JAN-2004 Doc #:22343403
Cust Comments: REAR PINION SEAL LEAKING
Tech Comments: VERIFIED CONCERN FOUND REAR PINION SEAL LEAKING OIL R AND R SEAL NOW OK
1FTWX33FX2EC72889 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 03-APR-2002 12-JUN-2002 174542 USA 20 7M01 150101 * 18C815 * A07 42 31007
AWS Claim Key: 9660632 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: 67701 - * Name: VISTEON AFTERMARKET-U.S. Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:12-JAN-2004 Doc #:68362709
Tech Comments: REQUESTING DEALER'S P/A CODE 08621
1FTWX33FX2EC72889 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 03-APR-2002 12-JUN-2002 174542 USA 22 5G02 040103 4C3Z 3049 DA C50 69 34530
AWS Claim Key: 9506047 Trx Code: E84 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 08621 - * Name: SEEKINS FORD/LINCOLN-MERCURY, INC. Ph: 907-4594000 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:17-MAR-2004 Doc #:22737601
Cust Comments: STEERING BINDS WHILE DRIVING
Tech Comments: R & R LEFT UPPER AND LOWER BALL JOINTS
1FTWX33FX2EC72889 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 03-APR-2002 12-JUN-2002 174542 USA 22 5J03 040302 3C3Z 18125 LD H45 D8 34530
AWS Claim Key: 9506046 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 08621 - * Name: SEEKINS FORD/LINCOLN-MERCURY, INC. Ph: 907-4594000 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:17-MAR-2004 Doc #:22737602
Cust Comments: REAR SHOCKS LEAKING FLUID
Tech Comments: R & R REAR SHOCKS
1FTWX33FX2EC72889 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 03-APR-2002 12-JUN-2002 174542 USA 22 5J01 040301 F81Z 18124 BG H45 D8 34530
AWS Claim Key: 9506045 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 08621 - * Name: SEEKINS FORD/LINCOLN-MERCURY, INC. Ph: 907-4594000 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:17-MAR-2004 Doc #:22737603
Cust Comments: FRONT SHOCKS LEAKING
Tech Comments: R & R FRONT SHOCKS
1FTWX33FX2EC72889 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 03-APR-2002 12-JUN-2002 174542 USA 57 7S12 030008 F81Z 9D930 AB E68 42 61248
AWS Claim Key: 15971535 Trx Code: E72 Labor Hrs: 3.8
Dlr Cd-Sub Cd: 08621 - * Name: SEEKINS FORD/LINCOLN-MERCURY, INC. Ph: 907-4594000 St:AK Ctry Cd: USA Reg Cd: NA Repr Date:22-JAN-2007 Doc #:29390701
Cust Comments: DIED AFTER STARTING ENGINE COMPARTMENT COVERED WITH FUEL E68 GIVE EST IF NOT WARRANTY.
Tech Comments: INSPECT FOR FUEL LEAK, NONE FOUND. ENGINE WILL NOT CRANK. CHK BATTERIES AND CHARGING SYSTEM, BOTH OK. CHK STARTER, INOP. REPL FAULTY STARTER. ENGINE NOW CRANKS, BUT STILL WONT START. CHK FOR DTCS, P1294 P1316. REFER TO PIN POINT TESTS. MTIME TO PERFORM MULTIPLE PIN POINT TESTS. REPL FAULTY LT UVC HARNTESS. RETEST AND ROAD TEST.
