Smokin
I would like to run an oasis on my truck just to see how much has been replaced on it. Thanks 1FTSW21P86EA56696
OASIS RESULT:
1FTSW21P86EA56696
03/04/2008
20:31:34
FCXWS447
© Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
6F710D0A
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 07-05-04
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 08-04-07
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 08-03-07
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/30/2005 BUILD DATE
06/27/2005 SALE MILEAGE
00512
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
02/14/2008
DEALER: Rountree Ford Lincoln Mercury
WARRANTY CLAIM NUMBER: 830606 ODOMETER: 029543M
LABOR OP
CONDITION CODE
CONDITION DESC
YC3Z 7G360AA MOTOR ASY 001 MT7G360 42 DOES NOT OPERATE PROPERLY
CONTROL MOTOR DID ENGAING CORECTLEYE TESTED FOR CODE. PREFORMED PINPOINT TEST REPLACED 4X4 CONTROL MOTOR
01/31/2008
DEALER: Visteon Aftermarket - U.S.
WARRANTY CLAIM NUMBER: 269676 ODOMETER: 029030M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3T 18C815AC RECEIVER-ELECT CMPCT 000 42 DOES NOT OPERATE PROPERLY
PI12 001
REQUESTING DEALER'S P/A CODE 06450
01/29/2008
WARRANTY CLAIM NUMBER: 828593 ODOMETER: 029035M
LABOR OP
CONDITION CODE
CONDITION DESC
18806 CHASSIS RADIO 000 18805D 42 DOES NOT OPERATE PROPERLY
000 18805E
INTERNAL MAL. REPLACED RADIO AND PROG.
01/29/2008
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 8575AA THERMOSTAT 001 12650D 69 FROZEN/SEIZED/BINDING
000 8575B1
BINDING THERMOSTAT CC 69 DIAG FOR NO HEATER. FOUND THERM TO BE STUCK OPEN. REPLACE THERMOSTAT. RECK. OK
01/29/2008
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 12B599AARM IDM MOD ASY-FUELINJ 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F1X1
000 6005F2
000 6005F13
000 12650D67
FAILED CC 42 RUN DIAG TESTS.FOUND DTC P0611.RUN PINPOINT TEST. REPLACE FIC M AND REPROGRAM. CLEAR CODES.ROADTEST AND RETEST.OK
01/29/2008
LABOR OP
CONDITION CODE
CONDITION DESC
XY 75W140QL 004 4205A D8 FAILED GASKET/SEAL
TA 32 SPARK PLUGS 001
XL 3 003
4204 CASE ASY-DIFFERENTIA 000
DIFF DIAG REPLACE INSP COVER GASKET LEAKING MILEAG E ENTERED ON CURRENT REPAIR IS CORRECT, RO828196 1/25/08 MILE 29029, RO82859 3 1/29/08 MILE 29035, RO830606 2/14/08 MILE 29543.
01/29/2008
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 2523209AA REGLTR,F/DR POWER 001 23943AB 41 STICKS/BINDS/GRABS
000 23943A10
REG. BINDING R&R LF DOOR PANEL AND REPLACED POWER WINDOW REGULATOR.
01/29/2008
LABOR OP
CONDITION CODE
CONDITION DESC
TAP3 RENTAL - LINC LESS S 000 82 FREIGHT/POSTAGE/MAINTENANCE
CLAIM FOR TRANSPORTATION ASSISTANCE - INV 904008 $90.00
01/25/2008
WARRANTY CLAIM NUMBER: 828196 ODOMETER: 029029M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 003 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F1X1
000 6005F2
000 6005F33
000 6005F13
000 6005F45
000 9527AL
FAILDE INJECTORS CC 42 RUN DIAG TESTS. FOUND DTC P0266,P0278,P0284.RUN PIN POINT TEST. REPLACE INJECTORS # 2,6,8. CLEAR CODES.ROADTEST AND RETEST. PASS
01/25/2008
LABOR OP
CONDITION CODE
CONDITION DESC
CLAIM FOR TRANSPORTATION ASSISTANCE - INV 903928 $150.00
01/25/2008
LABOR OP
CONDITION CODE
CONDITION DESC
BXT 65750 MOTORCRAFT BATTERY 001 10654C 42 DOES NOT OPERATE PROPERLY
000 10654C1
FAILED BATTERY CC 42 DIAG FOR SLOW CRANK. TEST CHARGING SYS. 13.8 VOLTS. C HARGE BATTERYS AND TEST. REPLACE RIGHT SIDE BATTERY. ON PREVIOUS REPAIR 7971 85 06-04-07 THE LEFT SIDE BATTERY WAS REPLACED WRONG LINE NUMBER USED ON BATTERY TESTER, CORRECTED
09/14/2007
WARRANTY CLAIM NUMBER: 811309 ODOMETER: 028706M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9P456AF COOLER - EGR 001 8005D D8 FAILED GASKET/SEAL
VC 7B 002 9456A
6C3Z 5A231AA CLAMP-MUFFLER 001
LEAKING EGR COOLER CC D8 RUN DIAG TESTS.PRESS TEST COOLING SYS. FOUND EGR COOLER TUBE LEAKING. ROADTEST AND MONITOR PIDS. TEMP DIFFERENCE FROM ECT AND EOT WAS 13 DEG. REPLACE EGR COOLER TUBE ADD TWO GAL COOLANT AND ROADTEST. O K
07/30/2007
WARRANTY CLAIM NUMBER: 804608 ODOMETER: 027080M
LABOR OP
CONDITION CODE
CONDITION DESC
7000 TRANSMISSION ASY-AUT 000 7000F 42 DOES NOT OPERATE PROPERLY
3C3Z 7J136AA SOL ASY-TRANS DIR EL 001 7000F2
3C3Z 7C155DA GSKT CONTROL VALVE 001 7191A
3C3Z 7A098AA SCREEN ASY - OIL PAN 001 7191AXQ
F6TZ 7A191A GASKET OIL PAN 001 7191A1
XT 6QSP 009 7191A2
000 7191A10
ELECT TRANS DIAG R-R PAN NO CONTAMINATION AT ALL R-R SOLINIO BODY AND CLEAN AND REPLACE SSP-D SOLINOID STICKING
07/30/2007
LABOR OP
CONDITION CODE
CONDITION DESC
12A650 PROCESSOR ASSY 000 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F1X1
000 6005F2
000 6005F6
000 MT12650D84
DIESEL DIAG TEST 1-5 RECAL PROCESSOR ROAD TEST OK
07/27/2007
WARRANTY CLAIM NUMBER: 804292 ODOMETER: 026123M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 6C640A CONNECTION A/C DUCT 001 6005F 63 WEAK/SOFT/SAGGED (INSUFFICIENT PRESSURE)
6C2Z 6K786AA CLAMP AIR COOLING 002 6005F1
000 6005F1X1
000 6005F13
000 6646AH
HOSE SOFT CC 63 RUN DIAG TESTS. FOUND DTC P2262. RUN PINPOINT TEST. REPLAC E CAC HOSE ON HOT SIDE ON TURBO. FOUND TORN. RETEST. PASS
06/27/2007
WARRANTY CLAIM NUMBER: 120083 ODOMETER: 025310M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3T 18C815CB RECEIVER-ELECT CMPCT 000 42 DOES NOT OPERATE PROPERLY
PI91 001
06/26/2007
WARRANTY CLAIM NUMBER: 800164 ODOMETER: 025310M
LABOR OP
CONDITION CODE
CONDITION DESC
000 18805E
REPLACED RADIO WITH EXCHANGE UNIT
06/13/2007
WARRANTY CLAIM NUMBER: 798419 ODOMETER: 024658M
LABOR OP
CONDITION CODE
CONDITION DESC
F37Z 13550AA LAMP ASSY REAR LICEN 001 MT13550 33 LOOSE PART
POOR FIT WILL NOT STAY IN PLACE KEEPS COMING LOOSE, INSTALL NEW LIC PLATE LA MP
06/13/2007
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 7210CA LEVER GEAR SHIFT 001 7000F 42 DOES NOT OPERATE PROPERLY
5C3Z 7E395C CABLE ASY TRNS SHIFT 001 7000F2
5C3Z 7000KRM TRANSMISSION ASY-AUT 001 7000A
2W4Z 7B155D FLTR&HD ASY TRNS OIL 001 7000AXQ
000 7000AZJ
000 7000A11
000 7000A43
000 7095C
000 MT7005
000 7210A
000 7395A
000 7000F13
APROVAL CODE PAALU ELECT TRANS DIAG CODES 0766 0722 2700 R-R TRANS AND IN SPECT FWD AND DIRECT DRUM SIEZED TOGHETER FILL OUT HOTLINE FORM OVER COST CA P REPLACE TRANS PER HOTLINE REPLACE COOLER AND INSTALL COOLER FILTERS FLUSH LINES ROAD TEST OK E E E
06/04/2007
WARRANTY CLAIM NUMBER: 797185 ODOMETER: 024207M
LABOR OP
CONDITION CODE
CONDITION DESC
BXT 65750 MOTORCRAFT BATTERY 001 6005E 42 DOES NOT OPERATE PROPERLY
000 10654CA
000 10654C1
BAD CELL DIAG FOR NO START, CHG BOTH BATTERYS AND TEST, REPL BATTERY ON L EFT SIDE, CK CHARGING SYS, OK
06/04/2007
LABOR OP
CONDITION CODE
CONDITION DESC
F37Z 13550AA LAMP ASSY REAR LICEN 001 999A 42 DOES NOT OPERATE PROPERLY
1 REPLACED LICENSE PLATE LAMP HOUSING
03/13/2007
WARRANTY CLAIM NUMBER: 785890 ODOMETER: 022841M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 6051EA GASKET CYL HEAD 002 8005D D8 FAILED GASKET/SEAL
3C3Z 9229AA GASKET CARB FUEL INL 008 6051AT
VC 7B 002
3C3Z 6731AA ELEMENT ASY OIL FILT 001
XO 15W40QSD 015
3C3Z 9433AA GASKET SET-MANIFOLD 001
FAILED HEAD GSKS CC D8 DIAG FOR OVER HEATING. PRESS TEST COOLING SYS.NO EX TERNAL LEAKS FOUND.ROADTEST WITH VACUUM GAUGE ON COOLING SYS. FOUND PRESS TO BE EXCEDING 16 PSI. REPLACE BOTH HEAD GSKS. REMOVE AND REPLACE ALL NESSARY COMPS. REPLACE O-RINGS ON INJECTORS. ROADTEST.OK
03/05/2007
WARRANTY CLAIM NUMBER: 784652 ODOMETER: 022491M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 7G383AA EPC SOLENOID 001 7000F 41 STICKS/BINDS/GRABS
3C3Z 7C155DA GSKT CONTROL VALVE 001 7000F2
XT 6QSP 010 7191A
F6TZ 7A191A GASKET OIL PAN 001 7191AXQ
3C3Z 7A098AA SCREEN ASY - OIL PAN 001 7191A1
000 7191A2
000 7191A10
1 ELECT TRANS DIAG R-R SOLINIOD BODY AND REPLACE LPC SOLINIOD STICKING RO AD TEST OK
03/05/2007
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 15200AA LAMP ASY-FOG 001 15200AT 01 BROKEN/CRACKED
6C3Z 15200BA LAMP ASY-FOG 001
BROKEN LOWER MOUNTS REPLACED BOTH FOG LAMPS
03/05/2007
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 7863388BA CVR R/SEAT SUPPORT 001 999A 07 IMPROPERLY ADJUSTED/FITS POORLY
5C3Z 7863388CA CVR R/SEAT SUPPORT 001
BROKEN MOUNTS REPLACED RIGHT REAR SEAT ANCHOR BOLT COVERS.
| On-line 1878
END OF OASIS REPORT FOR 1FTSW21P86EA56696
