1FDXX47P44EC72219
Ford OEM Parts Supplier
OASIS RESULT:
1FDXX47P44EC72219
USA
EN
04/26/2010
08:10:55
FCXWS447
© Copyright 2002-2010 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-450 S/CAB CHASSIS CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
G8 ENGINE CALIBRATION
PAINT COLOR
OXFORD WHITE WB C/C-W/B RADIO
ELETR AM/FM/STRO/CSTE/CLOCK GROSS VEHICLE WEIGHT
15,000 LB. GVW
AXLE RATIO
4.88 FINAL DRIVE RATIO WHEEL SIZE
6.0 X 19.5 STEEL WHEELS FRONT TIRE
225/70/R-19.5 BW F:A/S R:TRAC
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
Click here for CUDL
ARN MESSAGES
INSTALL 6A642-CA KIT WHEN REPLACING EGR COOLER UNDER 09-08-03
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 09-08-03
TO ENSURE OPTIMUM COOLING SYSTEM PERFORMANCE, REFER TO 09-08-05
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
12/10/2004 BUILD DATE
03/20/2004 SALE MILEAGE
00010 New Vehicle Base Warranty
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0701 - USA 2005 NEW 72/100,000 POWERTRAINCARE W/ROADSIDE
STANDARD DEDUCTIBLE: 50 USD
OWNER NAME: MILLENIUM HOMES LLC
OPTIONS:
EXPIRATION DATE: 12/10/2010
DISTANCE: 100,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 20559
ESP CONTRACT START DATE: 12/10/2004
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
For competitive make ESP part verification click here
WARRANTY REPAIR HISTORY
Standard Claims List For Model Year 2004
1FDXX47P44EC72219 T/F7 F T/BD T/DB T/E A1 T/BE T/YB 20-MAR-2004 10-DEC-2004 113467 USA 2 6Y20 000001 * MISC * A99 82 642
AWS Claim Key: 4556335 Trx Code: P01 Labor Hrs: 0
Dlr Cd-Sub Cd: 03623 - * Name: LOMAN FORD, INC. Ph: 732-6363200 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:24-JAN-2005 Doc #:01569452
Cust Comments: GOODWILL CAR PAYMENTS AS PER LESLIE JACKSON,$1500.00,,,AUTH#K15RV
Tech Comments: CAR PAYMENTS PER FORD REP L. JACKSON
1FDXX47P44EC72219 T/F7 F T/BD T/DB T/E A1 T/BE T/YB 20-MAR-2004 10-DEC-2004 113467 USA 2 3A03 * * * * * * 642
AWS Claim Key: 4603053 Trx Code: 04B24 Labor Hrs: 10.7
Dlr Cd-Sub Cd: 03623 - * Name: LOMAN FORD, INC. Ph: 732-6363200 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:24-JAN-2005 Doc #:01569451
Cust Comments: C S TOW HAUL LIGHT ON,TRANS SLIPS IN FORWARD AND REVERSE OTHER IS 30% TRANS MARK UP MINUS HANDL
Tech Comments: VERIFY CONCERN PER 04B24KOEO P2700 P2701 KOEC P2702 P2703 KOER P0841 P0846, FOUND CARRIER PIN WALKED OUT OF LOW REVERSE PLANETARY CAUSING DAMAGE TO LOW REVERSE RING GEAR HUB, FORWARD, DIRECT, INTERMEDIATE, OD CLUTCHES. PARTS ON BACKORDER TILL MID FEB. CONTACT FORD & GIVEN AUTHORIZATION TO REPLACE UNIT. REPLACE TRANS & O TO A COOLER. INSTALL IN LINE & REMOTE FILTERS. FLUSH COOLER & LINES. CLEAR COD
1FDXX47P44EC72219 T/F7 F T/BD T/DB T/E A1 T/BE T/YB 20-MAR-2004 10-DEC-2004 113467 USA 3 2E06 030008 3C3Z 9E527 AE D50 01 1051
AWS Claim Key: 4338453 Trx Code: S07 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 03623 - * Name: LOMAN FORD, INC. Ph: 732-6363200 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:28-FEB-2005 Doc #:01773952
Cust Comments: CUST STS VEH HAS A MISS FROM ENGINE
Tech Comments: PERFORM DIESEL PERFORMANCE DIAGNOSIS. KOEC P0284. PERFORM INJECTOR ELECTRICAL TEST #4 CRACKED. REPLACE INJECTOR. CLEAR CODE.
1FDXX47P44EC72219 T/F7 F T/BD T/DB T/E A1 T/BE T/YB 20-MAR-2004 10-DEC-2004 113467 USA 3 2G05 031405 * RECAL * G29 42 1051
AWS Claim Key: 4338452 Trx Code: 2 Labor Hrs: 1
Dlr Cd-Sub Cd: 03623 - * Name: LOMAN FORD, INC. Ph: 732-6363200 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:28-FEB-2005 Doc #:01773951
Cust Comments: CUST STS WATER IN FUEL LIGHT IS ON
Tech Comments: REVISED CALIBRATION PER TSB 4 19 4, REPROGRAM PCM & ROAD TEST.
1FDXX47P44EC72219 T/F7 F T/BD T/DB T/E A1 T/BE T/YB 20-MAR-2004 10-DEC-2004 113467 USA 10 * * * * * * * 6247
AWS Claim Key: 7069687 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 03623 - * Name: LOMAN FORD, INC. Ph: 732-6363200 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:26-SEP-2005 Doc #:02816154
Cust Comments: 05E15 RECALL
Tech Comments: RECALL 05E15 REPLACE EP SENSOR & RECALIBRATE CONTROL MODULES
AWS Claim Key: 7069686 Trx Code: 05S34 Labor Hrs: 1
Dlr Cd-Sub Cd: 03623 - * Name: LOMAN FORD, INC. Ph: 732-6363200 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:26-SEP-2005 Doc #:02816153
Cust Comments: 05S34 RECALL
Tech Comments: RECALL 05S34 INSPECT FICM WIRE HARNESS & INSTALL FICM REPAIR KIT
1FDXX47P44EC72219 T/F7 F T/BD T/DB T/E A1 T/BE T/YB 20-MAR-2004 10-DEC-2004 113467 USA 10 2H01 * * * * * * 6247
AWS Claim Key: 7069685 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 03623 - * Name: LOMAN FORD, INC. Ph: 732-6363200 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:26-SEP-2005 Doc #:02816152
Cust Comments: 05B29 RECALL
Tech Comments: ONP 05B29 REPLACE CAC DUCT & CLAMPS
1FDXX47P44EC72219 T/F7 F T/BD T/DB T/E A1 T/BE T/YB 20-MAR-2004 10-DEC-2004 113467 USA 23 5A11 0502XX F81Z 4621 BA N51 41 26439
AWS Claim Key: 10801506 Trx Code: E84 Labor Hrs: 7.5
Dlr Cd-Sub Cd: 03623 - * Name: LOMAN FORD, INC. Ph: 732-6363200 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:05-OCT-2006 Doc #:04326051
Cust Comments: CUSTOMER STATES HUMMING NOISE IN REAR Q
Tech Comments: PERFORM DIAG ROAD TEST CONFIRM EXCESSIVE NOISE REMOVE REAR EX PLAY 3.5MM SIDE TO SIDE AT PINION FLNAGE OPEN DIFF INSPECT FOUND BEARINGS ADN RACES GALLED EXCESSIVELY RING AND PINION OK RR INNER AND OUTER PNION BEARINGS AND RACES RR PINION SEALS CLEAN RECEHCK PINION DEPTH AND CONTACT PATTERN OKR EASSEM ROAD TEST OK
1FDXX47P44EC72219 T/F7 F T/BD T/DB T/E A1 T/BE T/YB 20-MAR-2004 10-DEC-2004 113467 USA 31 2E06 100106 3C3Z 9C407 AB D02 42 30347
AWS Claim Key: 11854953 Trx Code: E84 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 03623 - * Name: LOMAN FORD, INC. Ph: 732-6363200 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:25-JUN-2007 Doc #:05135851
Cust Comments: CUSTOMER STATES TOWED IN,VEHICLE DIED ON ROAD,CRANKS....DOES NOT START
Tech Comments: CHECK AND CONFIRM NO START BUT CRANKS EEC TEST CODES 232 266 272 299 CEHCK FUELPRESSURE 0 PSI CHECK POWER TO FUEL PUMP 12VOLTS CHECK FOR SIGNAL TO PCMOK REPLACE FUEL PUMP REASSEMBLE RECHECK FUELPRESSUR 45PSI REPROGRAM PCM RECHCK OK
1FDXX47P44EC72219 T/F7 F T/BD T/DB T/E A1 T/BE T/YB 20-MAR-2004 10-DEC-2004 113467 USA 51 1H03 030008 5C3Z 9F452 AA D42 55 38905
AWS Claim Key: 13090360 Trx Code: S07 Labor Hrs: 1
Dlr Cd-Sub Cd: 03623 - * Name: LOMAN FORD, INC. Ph: 732-6363200 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:05-FEB-2009 Doc #:06810751
Cust Comments: CUSTOMER STATES VEHICLE SMOKES
Tech Comments: CHECK AND CONFIRM WHITE SMOKE FROM TAIL PIPE NO POWER CK ENGINE CODES 404 470 1335 PERFORM DIAG CHECK AND REFER TO TSB 8 26 12 FAILED EGRA MECHANICAL TEST NECESS TO REPLACE EGR VALVE AND DPGE SENOSR SHORTED OUT REASSEMBEL RECHECK OK
1FDXX47P44EC72219 T/F7 F T/BD T/DB T/E A1 T/BE T/YB 20-MAR-2004 10-DEC-2004 113467 USA 51 2H01 0300XX * 6K682 * D42 42 38905
AWS Claim Key: 13090362 Trx Code: S07 Labor Hrs: 3.7
Dlr Cd-Sub Cd: 03623 - * Name: LOMAN FORD, INC. Ph: 732-6363200 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:05-FEB-2009 Doc #:06810753
Cust Comments: CUSTOMER STATES VEHICLE HAS NO POWER
Tech Comments: CHECK ADN CONFIRM NO POWER PERFORM DIAG REFER TO TSB 8 16 13 CODE P0299 CHECK AND PINPOINT TO TURBO ASSY NECESSARY TO REMOVE TURBO PERFORM OVERHAUL PASSED REPLACE DRAIN TUBES REASSEM RECEHCK OK
1FDXX47P44EC72219 T/F7 F T/BD T/DB T/E A1 T/BE T/YB 20-MAR-2004 10-DEC-2004 113467 USA 51 1A02 030102 * 6051 * L87 42 38905
AWS Claim Key: 13090361 Trx Code: E72 Labor Hrs: 9.1
Dlr Cd-Sub Cd: 03623 - * Name: LOMAN FORD, INC. Ph: 732-6363200 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:05-FEB-2009 Doc #:06810752
Cust Comments: CUSTOMER STATES VEHICLE IS LOSING COOLANT
Tech Comments: CHECK ADN CONFIRM COOLANT LEAK PERFORM DIAG CHECK ADN REFER TO TSB 8 11 03 PINPOINT OT EGR COOLER LEAKING COOLANT OBTAIN PRIOR APPROVAL NECESSARY TO REPLACE EGR COOLER REASSEMBEL RECHEKC OK CODE PAAGS
1FDXX47P44EC72219 T/F7 F T/BD T/DB T/E A1 T/BE T/YB 20-MAR-2004 10-DEC-2004 113467 USA 51 2E03 03XXXX * 12B599 * D02 42 38905
AWS Claim Key: 13090363 Trx Code: S07 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 03623 - * Name: LOMAN FORD, INC. Ph: 732-6363200 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:05-FEB-2009 Doc #:06810754
Cust Comments: CUSTOMER STATES STATES HARD START
Tech Comments: CHECK ADN CONFIRM HARD START PERFORM DIAG CODES 266 269 RUN OASIS REFER TO TSB 8 26 3 NECESSARY TO REPROGRAM FICM PCM ADN TCM ROAD TEST RECEHCK OK
1FDXX47P44EC72219 T/F7 F T/BD T/DB T/E A1 T/BE T/YB 20-MAR-2004 10-DEC-2004 113467 USA 51 5A11 0502XX F81Z 4621 BA N51 41 38905
AWS Claim Key: 13075578 Trx Code: 0701D Labor Hrs: 7.1
Dlr Cd-Sub Cd: 03623 - * Name: LOMAN FORD, INC. Ph: 732-6363200 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:10-FEB-2009 Doc #:06818751
Cust Comments: CUSTOMER STATES THERE IS A NOISE IN REAR AT HIGHWAY SPEEDS
Tech Comments: CHECK CONFIRM NOISE IN REAR END ON ACCELERATION DISASSEMBEL REAR PINION BEARINGS SCORED AND SIDE BEARING NECESSARY TO REPLAR ALL BEARINGS ANDN SEALS RESET PINION DEPTH ADJUST BACKLASH ROAD TEST OK
