Would some one be able to post the Oasis report for the following VIN
1FTSW21P25EA60774
2005 F-250SD 4x4 CC 6.0 psd
Thanks,
laduckdog
OASIS RESULT:
1FTSW21P25EA60774
05/15/2007
20:47:41
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-17-06
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 06-23-02
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 07-05-04
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/13/2004 BUILD DATE
08/30/2004 SALE MILEAGE
00010
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
05/09/2007
DEALER: Banner Ford
WARRANTY CLAIM NUMBER: 156067 ODOMETER: 045330M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9P455AB SE E/G/R VLV 001 061906A 42 DOES NOT OPERATE PROPERLY
000 12650D84
45352 EGR VALVE, CALIBRATION UPDATE WARRANY PERFORMANCE DIAGNOSIS, CODES P0 299, TURBO CHARGER UNDER BOOST, P0470, EXHUAST PRESSURE SENSOR, P0341 CAMSH AFT POSITION SENSOR A CIRCUIT RANGE-PERFORMANCE, PERFORMED PINPOINT TEST KA 1- KA5, FAILED EGR SYSTEM TEST, REMOVED EGR VALVE FOR INSPECTION, FOUND CLO GGED WITH CARBON, CLEANED AS PER TSB 06-1-6 RECALIBRATED MODULES TO
08/12/2006
DEALER: Gateway Ford, Inc.
WARRANTY CLAIM NUMBER: 065470 ODOMETER: 033869M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6079C GASKET SET-VALVE GRI 001 12650D 42 DOES NOT OPERATE PROPERLY
3C3Z 6A831AA GSKT-OIL FLTR ELEM S 001 12650DX1
4C3Z 9P456AC COOLER - EGR 001 6051AT
W300051 004 6051A11
W300013 004 6051A20
388898S 001 8005D
VC 7B 002
3C3Z 6731AA ELEMENT ASY OIL FILT 001
XO 15W40QSD 016
XT 5QMC 002
VERIFIED CONCERN REMOVED EGR VALVE TO SEE IF THERE WAS WATER COMING FROM EG R COOLER NO WATER FOUND REMOVED HEADS REPLACED HEAD GASKET AND RESTORED V EHICLE
05/26/2006
WARRANTY CLAIM NUMBER: 063921 ODOMETER: 030627M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 19980AA CONTROL A/C 001 19980A 42 DOES NOT OPERATE PROPERLY
TEST AND REPLACED EATC
END OF OASIS REPORT FOR 1FTSW21P25EA60774
Thanks Corey
Thanks Corey :Thumbup:
