Just like to know if I am the only one needing to reset my DD seems like every 10 are so starts i need to unplug n reset the DD - Turns on but like if freezes are something anyone else needing to do this.:bang
Mine does the same thing.
Maybe mick will chime in here but tmk its a firmware problem and when updated this problem is fixed.
good that seems to be the only problem i got with it
Spartan, True Performance
ShowGun - You must put the DashDAQ into sleep mode, or power it down when you turn the truck off. Otherwise it will not be able to pick up the signal after the truck is shut off and then restarted. Best thing to do is press and release the power button quickly to put it into sleep mode, then do the same thing again after you start the truck. Sent you a pm with my cell number.....
Ok i'll try that next time - I'll let ya know if that helps me before i'll call :thumbsup
Tanks mick so far so good:happymugs
