The 'Check A/C' light is on in my 2005 4300 International. Is there a way to reset that light, or find out if there are any 'codes' as to why it's on?
Thanks!
to get your ac code engine off ign on and i think you hold your cruise control switch on and the set/resume switch bottom.[push and hold the top of the one switch and push and hold the bottom of the other switch] your dash codes should come up on your dash screen where the odometer is.
Thanks for the help! Now, I can't seem to find any info on the codes I pulled.
1:7
613_14A
29:2
612_14P
150:1
2023_14P
Can anyone shed some light on these codes?
Thanks!
Thanks! Is there a way to clear the codes without a scan tool?
at the end of the codes ,the a means active and the p means previously active . you can not clear active codes.once code goes to p {or inactive } after repairs made, try putting on the left turn signal and with key on ,eng off hold down the cruise on button and the resume button at the same time Bob
