my nephews truck.....09 1 ton....has an issue with the reverse lights....might be the fuse....he has checked owners manual but can't find any info on where the fuse might be in the fuse block....any help would be appreciated
TDG Mafia Member #25
Found it on page 305 of the manual. Spot 33 of the underhood fuse box. I would start with checking there, and if good check for power on the reverse pin of the trailer connector which has a separate fuse. If both are dead I'd suspect the MLPS on the tranny.
Adrianspeeder
