Can you use an sct on a 95? Also looking for one to utilize the injectors with stock nozzles.
I've programmed quite a few late 95, 96, and 97 trucks. Some of the trucks are kind of in between OBD1 and 2, so they are able to use a programmer.
Call and ask Tadd, I know he has tuned a few, but I dont know if they used a SCT.
If you have a late 94 build then your PCM may not be OBDII compliant. Check that out and let us know. Jody can flash your PCM to a later code to make it programmer friendly if it is. :Thumbup:
