Singles Club #2
Hey guys...im looking at buying a 2002 cummins...the body looks great...has 114k...unfortunately its an auto...and the only problem i could find was that the shift lever was hard to pull down...anybody have any ideas why it would be hard to pull?? thanks
hard as in something is putting it in a bind, or just tight w/o any slack like a new truck.
Singles Club #2
its tight like it would be binding
Check the linkage arm. All kinds of weird stuff can happen if that comes loose or gets in a funny position on the rod coming out of the trans. It could be having trouble with some other part of the linkage too. that is where I would start, I doubt its something internal.
Singles Club #2
thanks...i'll check it out when i go to pick it up...if the bank would ever call back to set up a loan appointment
Was there ever a shift kit put in? I've never ran into it but I guess if a novice was putting in a shift kit he might be able to screw something up in the rooster comb.
Yeah, thats a good point. Either way, I would pull the linkage rod off of the shifter arm. the shifter arm being the one directly attached to the transmission, On the same little spindle that the TV cable attaches too. Pull the linkage off of that and check to see if that arm moves freely. If it doesn't, you have a problem inside the trans, if it does, then your problem is going to be a linkage problem, which I'm betting it is, but you never know.
Singles Club #2
I'm not sure if there was a shift kit put in...everything that i saw on the truck was stock except for the exhaust (4" muffler back)
