1 - 20 of 25 Posts
have a 2000 with stock splits, was wondering if i can take the singles out of like a 95 or 96 and use them.
it can work, but you would need some kind of chip to make them work properly
someone who knows much more about this will have to chime in
michael
because i was looking at diy site and you can get a bit more than stock out of them with armature pistons being redone, and i want single shot instead of split anyways. and its cheaper for those diy's
i planned on buying singles putting a diy kit in them and dp tuning them, and with them worked i cna use stock hpop since they say it takes less pressure to use singles than splits correct?
yes...they take less oil pressure to operate than split shots. If you have a healthy hpop...then this shouldn't be an issue. If your hpop is failing...then going to singles is a temporary band-aid.
Singles out of a 95 or 96 are AA's (around 90 cc's). Your 2000 runs 140'ish cc splits. What I'm getting at is you don't want to run AA's in a 2000, as you'll get much less power and be very disappointed.
You can get AC single shots and put those in your truck. Run some tuning for single shots, and that will give you a bit more power. AC's are typically called Stage I's.
And many single shots do use less oil. However, even singles can benefit from a stronger HPOP setup.
cool as december
put some hybrids in it!!! Like stated above be carefull with your choices but with a proper set up, youll have more power and better economy. What are your hp goals?
im looking for like 250 at the wheels with out changing turbos and going overkill on it...this is a daily driver
cool as december
oh that should be easy then, like pocket said that should get you there or maybe a little north of 250. Be sure to get the quite idle tune from jody too!
where would be the best place to get ac codes cheap?
you can build your aa's with rosewood's kit..stage 1's and be fine
MAFIA MEMBER 106
yes just send them to [email protected] rds i have his hybrids and love them jim is the man
250?:haha
You dont have to change a thing... 250 can be done with just a mild 40hp tune... Did you mean 350?:wedgie
Discussion Starter #15
im looking for good power but not anything that is gonna kill the life of my truck.
Chip, Intake and exhaust... 300hp and the only thing your likely to kill is the tranny. Anything above stock is going to start eating the tranny.
I would not change a thing, Intake, Exhaust, Tranny and maybe a 1.00 exhaust housing.
Looking at your mods in your sig I would say your right at 280 right now on your max setting on the programer.
Discussion Starter #17
hmmm the way it feels i thaught it had like 180 hahaha
Personally...before you throw new sticks at the truck, I would look into bigger oil. It is a great foundation to build off of.
With the addition of my first big oil setup...I was able to put 333 to the rears. This was with a stock turbo, stock injectors, an intake and exhaust, and Jody live tuning the truck. I did have the regulated fuel system setup at that time...but don't believe that adds any hp to the truck.
Discussion Starter #19
well after getting "smoked" by a duramax today... i want to go a different way about my truck... time to build alot of power
Not going to knock your set up, but I did 350 with a 38r and a little water injection...
I did 470 with water and a TN BB and hybrids. I really dont think oil is needed for 90% of the trucks out there.
But it is a differant route! :thumbsup
1 - 20 of 25 Posts
