I’ve got a basically stock 03 Ford 7.3 diesel that I’d like to modify just a bit at a time, as finances and time allow. So far all I’ve done on it is a 4” turbo back exhaust and ordered a chipset from DP. Next will be pillar gauges. I know next to nothing about the various models but would like to purchase a good quality set, pyro, trans temp, and boost. Please let me know what you would recommend.
Thanks,
Steve
home brew'n
Guages are a must with a chipped truck. Pick the type you like. Same goes for mounting locations. You will also want to address the air in aspect of the engine. You have a larger output but you should also open up the intake side with a DIY or an aftermarket type intake. There is a DIY article down in the Tech Articles section. It is for '94-'97 but it should lead you in the right direction.
Scott
We carry variety of gauges and mounting solutions. Feel free to call and I'll gladly describe all the options available.
