When i rev my truck up it sounds kind of sluggish, like its not hitting as high(for lack of a better word) as it could. It seems a little bit sluggish when driving around but when the TC is locked it spools up an runs good. Its stock so any ideas would be good!! THANKS!
TDG MAFIA MEMBER #77
Does it do this at all engine temps or just cold? If just when cold it may be that you are feeling the exhaust back pressure valve doing its part to warm her up quicker. If at all temps it could be oil related - as in it may be time for an oil change, or your HPOP is worn out and can't keep up with the demand to fire off the injectors.
Discussion Starter · #3 ·
Well i am leaking just a little bit of oil in the valley an its running down the front of the tranny so the hpop is goin to probably need to be replaced. Thanks do you know a rough estimate on the goin price of an hpop??
Never checked into it. If memory is right, the HPOP has O rings that may be leaking. I would look that way before spending big money when you may not need too.
MAFIA MEMBER 106
:whs o-rings 20 bucks hpop 400-1500 bucks do the o-rings
Discussion Starter · #6 ·
Direct me to a website where i can order some hpop o rings please...
