1 - 20 of 49 Posts
So what can you do to these 160hp/400tq Cummins diesel for power adders ?
I'm looking for 200-250hp/450-550tq, it'll be backed up by a 5 or 6spd manual transmission with 4.10/4.11 gears, and 225/70R19.5F M/T tires. . .
225/70R19.5 M/T's = 33" x 9" on 19.5" rim.
The battle plan:
Buy a 90-93 Dodge D350 4x4 dually, Cummins turbo diesel, manual trans.
then i want to add the 19.5 wheels n tires and adjust the power till tows how i'd like it too, then i want to remove the Dodge body, and install a 63'-88' Jeep J/10-J30 The full sized pickup truck cab n diamond plate flat bed, Duel stack's n 19.5 Radial Mud terrains mounted on polished Alcoa 19.5 dually wheels.
Mike
********* and Mafia #90
he just showed me the jeep cab, Its pretty sweet looking!
i believe fuel pin, governor, timing, get some bigger injectors. depending on turbo you might want to get a newer 12 or 14cm wastegated housing and drill out the wastegate. of coarse, intake and exhaust mods must be done.
3 different grill options, for these truck's below are the 3 pictured.
Mike
possible beds, i'm like they polished one myself, the truck cab will be painted Red, and the wheels will polished Alcoa's. . .
Mike
So the plan is mount a cab n bed like the above pictured onto a 8?'-93' Dodge ram dually 4x4 chassie with the 12V-5.9L cummins and a manual transmission. . .
Mike
Now you have an idea about what the completed project will look like, What to goal is to better help educate me on what i'll need to do to setup the drive train to match.
Mike
Sound rather easy :rock
Mike
will this Getrag !?!? 5spd handle some extra power ? or will a trans up grade be needed ?
Mike
the getrag should be able to handle the power. you arent going crazy with it. might just need a better clutch for towing.
Discussion Starter #12 (Edited)
You think it'll run down the road respectably ? with 200-250hp n 450-550tq, 5spd-OD, 4.10's and 33" x 9" 12ply F tires ?
Just looking for a stronger truck then the old 6.5er its replacing :woot:
So i need more then 150-175hp but i don't need a 400-600hp either.
i want to have all my power from 0-70mph, from 72mph+ it can start fading away, I want some good steady pulling power.
cruise 68-72mph on the highway, yet be able to grunt 12-15k-lb's up a long steep grade 65mph, so i'm thinking 225hp n 500tq should be plenty ? ? ?
Mike
Mike
you're probably going to need more than 225/500 to move 15k up a large grade at 65mph. id aim for 300/650 which isnt too hard.
Mike, there is absolutely no comparison between the two motors. Also there are way less wires for your mice to eat threw LOL.
Discussion Starter #16 (Edited)
Ya but for the few seconds it take to pass the grades around here, couldn't i just down shift and rev it for a few second's ?
EDIT:
Drive:
[email protected],000rpm.
[email protected],500rpm.
.75 OD:
down shift to 4th and wrap let it hum 2,600-2,800rpm for a few seconds ?
Mike, there is absolutely no comparison between the two motors. Also there are way less wires for your mice to eat threw .
:rock even if they did it'll prolly still start with a screw driver ? LOL just jump the starter . . .
Mike
Discussion Starter #17
I can always drop the gearing down to 4.33-4.56's If ya think it'll need a little more gear ?
Mike
just do 300/650 :D
Discussion Starter #19
1. will the Getrag 5er hold 300/650 ?
2. what will 300/650 Cost me to do ?
250/500, sound good enough for me if it's doggy it get's doggy still a far iprovment over 190/380 LOL :haha . . .
Mike
what gearing are you using to get you to 66mph at 2000rpm?
i have 4.10s and 33s on my dodge and check out my speed per rpm.
as for your question about what it will cost to make the power? let me see if i can break it down for you real quick.
3200rpm governor spring- $20
fuel pin- $200
POD injectors- $440
find a 12cm wastegated housing and that should be pretty cheap
that should easily get you to 300hp.
check out this setup, it is what i listed minus the injectors.
1 - 20 of 49 Posts
