1 - 10 of 10 Posts
Hey guys, Just wondering if the 150 tune is supposed to stop the regen cycle on the DPF. My truck hasn't gone through a regen in probably about 500kms. I just put the 150 tune on the other day with about 100kms on it since. This evening on the way to work it tried to go through a regen cycle but turned off as soon as it came on. Any ideas??
Thanks.
I've been considering getting a Spartan and only running the lower HP tunes that leave the DPF on. How do you like the 150? Do you notice a big increase in HP?
The 150 is very nice, and honestly I can't wait to get my exhaust on so I can load the 275. But the power gains on the 150 are very noticable.
Spartan, True Performance
If you loaded a dpf on tune then it will go into regen when it needs too. It will not display it on the Dash as some of the stock files do.....
Just make sure it is a dpf on tune that your running if the dpf is still on the truck and not a dpf off tune......
yeah, I did select the 150 DPF on tune. Just had a bad experience last time the "regen" came on then shut off right after (This WAS pre-tuned). But again, I love the tune. I did a nice smoke show this morning on the way home from work across an intersection until I let off the pedal. It was F'N awesome, even with the 150 tune the power gains are tremendous!
1 - 10 of 10 Posts
