I know there are several switches, brake, clutch, that turn off the speed control. Mine started working intermittently and now just quit. What switch or maybe not would be the most likely?
Speed Control
Mine was doing the same thing simple fix is the brake switch underneath the master cylinder. I do not remember if it was the front or back switch. Contact Ford they can walk you through which one. Easy repair
Same here. I replaced the switch on the master cylinder that is FARTHEST from the firewall. Lost very little fluid. A crows foot helps. Let us know if it helps.
Update........it was the brake switch. Thanks everyone
