if the speed sensor ring in my rear end isn't sitting right and its wobbling or whatever it does can i fix that or do i have to get it pressed in
MAFIA MEMBER 106
you have to remove the carrier and take off the ring gear to get to the exciter ring they have a little tab that sandwichis between the 2 good luck its a pain you will need a brass hammer for sure
