I've got a 4" SS exhaust tip for sale. It will either need to be clamped to the exhaust system or spot welded. I bought a complete kit for the Ex that had a tip. There is some road rash on the side of the tip that would face the tire. I will try to get some pictures of this thing up within a day or so.
$20 shipped...
TDG Mafia Member#67
whats the inlet? one of my buddies has a 4" exhaust and needs a tip..!
The end of the tip is expandable. I tried to put it over the stock exhaust on the Ex and it slid on without issue...so I am thinking that it would fit a 4" without issue. I will measure tonight and get pictures up as well.
TDG Mafia Member#67
ok thanks! if the inlet will accept 4" pipe ill prolly take it..
Here are some pictures of the tip. I measured the inlet and it comes to 3 3/4 so its most likely built for a stock exhaust. Not sure if a 4" pipe will slide easily on or not. The inlet side does look expandable though.
Anyway...lemme know your thoughts. If you wanna pass that's not a problem.
