Hello guys, I got a 2001 PSD at work that has been driving me nuts. The problem I'm having is the starter turns over all by itself with the key in the off position. I have replaced the starter solinoid, key switch and ignition switch. Still doing the same thing. I then traced all wiring and looked for cracks and splits, nothing. I'm at the end of options here, anyone with an idea? Thanks Andy
a friend of mine had the same problem,and his turned out to be the fuse box inside the cab
His windshield was leaking and the water leakedon the fuse box which oxidated the contacts inside the box
