1 - 13 of 13 Posts
I need a pic of an old style stc. What it looks like good and bad so I could see a difference. Or point in direction
********* and Mafia #90
Here is the latest fitting..
here is the first revision of a FIX for it. if you have the bracket you had it repaired once
This is the original style
ok i have the original style but by looking at it i can't tell if its bad or good. i will say that the o ring or black circle moves fwd and aft is it supposed to do that.
update it to the one piece while you have access to it or you will be sorry down the road!!!
yes i am going to replace it along with hpop. i just hope it fixes my truck and starts.
Do you have the part number for the one piece STC?
the new upgraded is 4c3z-9b246-f
Does this part fit in a 2006?
i am almost positive it does.
Do you know if Ford upgraded to the new part number at some point.
Do 2005's and later already have the new part number?
as of my knowledge they dont mine is an 05 and had old one on.
From what I think is they started putting the updated parts in early 06 models and so on
OK. I have an 06 that was made in 05, so mine probably has the old fitting. I'll probably just buy the new one so I have it when I do any work that gives me a chance to change it.
Thanks!
1 - 13 of 13 Posts
