1 - 20 of 62 Posts
Super Moderator
I got the engine Thusday(1/20), and started stripping off extra junk I dont need. I got antsy, and wanted to hear it run. Got some oil(14qts), and a gal of diesel. It took adding a second battery, and a bit of cranking & bleeding to finally start. It fired up, and runs really smoooth. This was after I advanced the timing a few degrees, cut the stock fuel plate into a #0, and tightened the gov springs. I'm stoked, because I paid $500 for it, and it has a P-pump, which I wasnt expecting.
The parts list needed seems pretty lengthy right now. I still need an SAE#3 bellhousing for the Allison AT545. Yeah, the 545 isnt exactly the top of the line choice, but it's a compact size, and still came in the F series truck. Part of the whole theme of "all Ford power". The rear gets a Sterling from a 91 F250, I got that for $60. Up front gets F250 spindles with 12.5" rotors & dual piston Dayton calipers. Then, hydrobooost to make it nice & easy to stop, since it has non-power assist 4 wheel drums now. The 300 that's in it still runs, and I'll need to box the frame, but I'm hopeful.
Size?
It's close to the same length of a DT466, but it's 5" shorter, so it's a little easier fit in a 2WD. It's going to have to go back into the firewall about as much as a 12 Valve does in a 2nd Gen Dodge.
Super Moderator
A few more pix. Check out the multi adjustable gov spring retainer. It allows 5 different settings for the idle spring. I set it in the shallowest notch, so I could crank the inner springs. Mission accomplished. It idles good, and throttle response is snappy, but not too sensitive, and revs to around 3k.
*^%$#@&am p;am p;am p;am p;am
Cool:peelout
since the truck will be be so light are you going to a low ratio diff for hiway criusing
Gone Fishin...
nevrenufhp, I've been waiting for you to start this thread since the day you put the info in your signature! Congratulations on the new engine and I cant wait to see the finished project!
:happymugs
Reactions: nevrenufhp
Super Moderator
It has 3.55's now, but I'm going to get 3.08 when I get the chance. After it's in & running. The truck weighs 3990 now, and that's still pretty light, compared to an F600. I'd guess it'll weigh around 5500 when it's done.
Hopefully I'll get decent mpg too.
my f350 9500 lbs :damnit
3.08 would be a nice ratio
my final drive with in top gear and in gearvendors overdrive is about 2.40 to 1 if my maths is correct
is your transmission an overdrive?
Super Moderator
No OD. it's 1:1 in 4th, and no lockup, unless I spring for the AT1545. I'm building this with as little budget as I can, since basically overtime pays for it, so I dont make the family suffer thru my "ambition".
Sure, an overdrive would be nice. So would a driveline retarder, an air compressor, and air conditioning.
TDG Mafia Goon
I like it. This is one of the more interesting swaps. That 545 is a great transmission.
Super Moderator
Discussion Starter #10 (Edited)
That is a P-pump, Right? Is there a reason why you did'nt opt for the 7.8 ford?
Yep, it's a P-pump, and I wasn't expecting it, being the engine's supposed to be a 92. But it was an Alliance drop in reman, dating to around 98-99. It should be pretty fresh, I dont see anything coming out of the draft tube when it's running.
Main reason for not using a 7.8? The deck height. They are roughly 3" taller than the 6.6, and if I did that, I would have sprung for the DT466 they had for $1000. Maybe for an all out drag truck, but not this time.
Since the truck has had a hard life with previous owners, I'm not too worried about preserving it. All the 2 tone body parts are from a 72 F250. I'll basically have an F250, except for what the VIN says. I'll be rolling at max GVWR, hopefully less. I hope to get a video of it running later today.
Maybe I'm overthinking the physics part, but since it has only a 4.4 stroke, I was thinking it should have pretty snappy response, and rev up to around 3800 pretty quick. Injector lines are so short, I see why the timing specs are set so low. I got the timing to 19*, and it already has light clatter. Nothing compared to the 466 at work when I set it to 24*.
Super Moderator
Discussion Starter #12
Oh, the poor little 300 that's in it now? It's slowly dying. I have to add a quart of oil every 2 weeks, but it has great power & a lovely 11 mpg. It has a mission. The other project.
I was thinking of a father daughter build. Get a 67-68 mustang for cheap. Find a Shelby or Eleanor front nose, and put the 300 with an AOD in it. It already has an Offy intake & 4bbl, along with a few other hop up parts. I'd do a refresh rebuild, since it was overhauled in 99. She wants to paint it Lime green, like a 71 Cuda. I figure, with that combo, it should get at very least of 15mpg, which is decent, but maybe better if I really dial it in & drop the choppy cam. It does sound cool though. Closed loop fuel injection would make it run a lot better in cold weather. She turns 14 in October, so we may be able to get it close to done by the time she turns 16.
TDG Mafia Goon
That's awesome. If I ever have them, my kids and I will build their first rides.
Super Moderator
Discussion Starter #14 (Edited)
Here's the videos. The first one took extra cranking because I pulled out the fuel hoses lastnight. It cranked a little slow on the second one, because I only had 1 battery hooked up.
The first fire up:
Gone Fishin...
Any updates to this?
Super Moderator
Discussion Starter #16
Not a lot. I did start painting the starter and some brackets. Sometimes next week I'll start painting the block. Slow and go. When I get off disability and back at work I can get to looking for a transmission.
Im glad you are taking the time to detail that motor.It will look that much nicer when youre showing off your hard work.what color will the engine be? :toytruck
Super Moderator
Discussion Starter #18
Since I have the time, I may as well tidy it up. Going for old school Ford light blue, with black brackets and aluminum on the intake & oil cooler. Pix will come as progress rolls.
TDG Mafia Goon
Awesome. I hope you're back on your feet soon.
Kee[ us updated; Im wondering what kind of mileage shell get
1 - 20 of 62 Posts
