1 - 14 of 14 Posts
What does a 2000 7.3 max out at for boost pressure? I just want to check my numbers that I have been getting.
Thanks!
AJ
My 02 will boost up to 24 PSI. That is as high as i've seen. It still has the stock turbo.....Hope that helps.
Mine is turning 28#'s before the damn safe mode kicks in and it drops to 25 or 26 pounds. I need to get a boostfooler:damnit .
my stock truck gets 17 if im lucky i can get 18 thats bone stock just exhaust..
I wouldn't be pushing it past 25psi with the stock turbine housing unless you want to buy a turbo.
The amount of extra power you make above 25psi isn't much either because the compressor is so far out of its map, it's making a lot of hot air which makes the boost gauge read higher, but in reality doesn't push much more volume of air into your engine at all.
I've never seen specs for a SD, but I do know that a done stock OBS truck will push a max of 12-14 psi of boost. My best guess would be that a SD should be about the same or maybe a tad more since there are a few minor differances between an OBS 7.3 & a SD 7.3.
Stock SD should be about 18-19#'s
Greg likes to put the fear of death in everyone about there turbos but they will last just fine over 25#'s... Yes they are out of there map range but there not going to grenade...
I have seen my share of toasted turbos.
Then again a sack of bushings (rebuild kit) is less than 100 bucks on eGay, so go for it!
I push mine to 28+ every now and then.
Thanks guys, my gauge tells me i read 18-19 psi max
AJ
No chip? Sounds right.
Mine isn't running at it's best potential and when i have the chip all the way up i can push almost 40psi out of my stock turbo and i'm going push it till it cann't take it anymore. Stock turbos take one hell of an *** whipping.
TDG Mafia - Booze Runner
I must agree with Joe on this one. My little guy handled over 25#'s quite a lot , until the Map sensor kicked in, never put a boost fooler on, might have been a good thing though; because I would've blown it to smitherines the way I drive......:smoke
so is there a way to fix that engine light from comming on and slowin down my truck?? i have a 99 f350 with a 120hp chip and i made that waistgate bypass. after i either shut my truck off or driving NICELY the light shuts off and the thing takes off like a rocket! once i hit about 28 pounds my light turns on but i can still climb her up to 33 pounds with the light on.
so is their a way to fix it or bypass it or get something to even the boost and fuel out??
I never said it wouldn't handle 25, I said OVER 25. How far over just depends on how short you want the lifespan of the turbo to be.
If you run it up to 27-28lbs "every now and then" you will probably notice no perceptible difference in the life of the turbo.
Go spin it to 35 every day for a week or two straight, get some really long pulls in there at sustained high boost levels like that, and high egt's, it will fly apart.
1 - 14 of 14 Posts
