1 - 14 of 14 Posts
Is anyone running just a flex hose in place of the muffler AND cat on their '94-'97 powerstroke??? If so is it loud? THANKS!!
Mod Friendly Title
Flex hose? No. Real tubing? Yes. Loud? Ish. LOL
I guess you could but...:umno:
Flex hose is a bad idea. Flex hose absorbs the sound in turn muffling the sound some. The best material for exhausts is a thick wall steel tubing.
a staight piece of pipe won't be that much more expensive AND it will last 10x longer
Why can't you use flex-pipe? EVERY class 6-7-8 truck has flex pipe in the exhaust system.
Would I use long sections of it to replace a muff, etc. in a system, NO. But good flex pipe works just fine.
I'd get a piece of stainless and use stainless band-clamps to install it.
MAFIA MEMBER 106
that stainless s flex is pricey as are the clamps save your$$$$ and get a good exhaust you can get em for 300-500 on ebay. better yet buy it from one of our vendors/sponsors here
Even if you buy an exhaust system I'd still buy the nice band clamps. Saddle clamps that come with the kits SUCK.
Stainless is the only way to go for exhaust systems.
Discussion Starter · #10 ·
Well i ordered a MBRP 4" turbo back today! So how hard is it to get the down pipe in???? THANKS
Not sure about the obs trucks, but my superduty was easy to install the down pipe. Just had to snake it up there. I have heard that you must notch out the firewall on the obs trucks depending on the size of the downpipe.
Discussion Starter · #12 ·
I think the dp is 3"...
Mod Friendly Title
The firewall is going to take some beating to get it in... The Superduties are different. My 4" DP just slid right in.
Ford Man
Yea, it takes a little beating to get it in there and not rubbing. Its worth the time and effort you put into it though.
1 - 14 of 14 Posts
