Hello all
My 08 350 spartan tuned (250) sb intake truck has a intermitten sound in the exhaust at idle and under exceleration. Sounds like a blower of some sort comes on for a minuet or two and shuts off for a bit then comes back on. Im not sure what the egr does but is it that? Hasnt always done this. Started about a year ago.
Thanks
At idle that might be the EGR cycling. This is done to prevent it from sticking due to carbon build up.
Thanks. What are the pros and cons of a egr delete? Truck sounds like a shop vac when it is on.
The pros are, you will be eliminating the EGR coolers. A possible source of coolant leak. Cons, if your truck needs to be smoged, it won't pass.
ADMIN/MAFIA
Is it the vanes of the turbo opening and closing?
Vaccume sound is getting louder and staying on. EGR stuck? Thinking of delete. No smog here.
