Currently runniny 310 with TCM, Switched over to the new stratagy tunes yesterday, followed all instruction to the T, re-installed the original TCM & loadded the truck back to stock, updated the DashDaq, purchased two new 2g sd cards, the non-tcm card made three folders transfer, tuning files, stock files. copy to the transfer folder Ref file to the transfer folder downloaded PhalanxUpdate & copy to the root directory of the sd card & installed the tunes, OK. everything went well with the convertion loaded the new 250 tune for non tcm.
Made second sd card for TCM tunes the following folders, transfer, tuning downloaded PhlanxUpdateTCM,
Removed stock TCM installed Spartain TCM & installed the TCM tune SD card tryed to load tunes & no tunes to load,
I have even tryed to copy tunes to both folders, I even tryed to put the license in the transfer folder.
I have done the following:
Re format the tcm SD card start fresh, re downloaded the tcm tunes, I get no error coded or messages, with tcm in, stratagy reads spartain1,spartain2.
License level 4
RefG4E64L
For now I removed the Spartain TCM & installed the OE TCM installed the PhlanaxUpdate stratagy SD card, no problems reading all tunes for non tcm, drove the truck, all is well.
I tell you what a diff from 310 w/tcm to 250 non tcm.
When you installed the level 4 license, did you go into the dd setup and install the license off the sd card and onto the dd? If you only put the level 4 license onto the sd card, the dd won't know it's there.
The first time I had installed the license on both cards in the transfer folders, when I went to install the tcm tunes my first step was installing license from the sd card the went to install tune & nothing to pick, I even though that the new sd card was falty even though I could read it on the computer so I took one of my back up sd cards & formated it & started fresh with it.
Question:
It snowed last night sow I can't install the tcm now, but I want to try something, If I installe the tcm sd card into the DashDaq will the DashDaq be able to read the tunes if the old tcm is in place, Not load Just READ?
Thanks for your help!
Chris
Question:
Chris
Don't know if it matters but in the transfer folder I also have the license REF #.
If the lisence is already installed & i am just switching sd cards from non tcm tunes to tcm tunes the DashDaq should just detect the new sd card & read it right?
I am able to load the non tcm tunes sd card ok with the stock tcm, just cant load the tcm tunes with the tcm installed off the tcm sd card.
Chris
Spartan, True Performance
Send me an email including the following info to [email protected]
With the Spartan TCM installed go to Vehicle Info and let me know what's it's showing for the strategy code. Bet it's something like spartaneng01 or 02 and spartandiesel02. It should be showing spartantm or spartantrans02. All I'll have to do is to make you another tcm tune to load on the truck. Once that's done you'll need to load it, then you'll be able to pickup all the tcm tunes. Also go to Status under the Tuning menu and let me know what's showing up there.....
Hello Mick
Re-installed Spartan TCM here are the following #'s
Strategy spartanengine1 spartandiesel2
CAL ID under tune:
Status under tuning:
lic 4
ECU 22-24
com 1
can I call you?
thanks
Chris
Sure,
828-702-3461
Sure,
828-702-3461
Hello Mick
Sorry it’s taken all day to get back to you, had to leave this morning, just got it & loaded your 310_tcm.enc file, worked like a charm! All is great. Now I can read all the tcm.gtf files.:peelout
I can’t say enough about your great service, Thanks goes out to all the Spartan crew, great team great products.:salute
