1 - 16 of 16 Posts
Got to play a little on the rollers today
#2 run 449 HP and 784 TQ
#2 and 1st shot of NOS 573 HP and 918 TQ
#2 and 2nd shot of NOS 639 HP and 985 TQ
CLAYTON DYNO
GENE
The Big Meanie
:Thumbup: :Thumbup: :Thumbup: :Thumbup: :Thumbup: :Thumbup:
kevin
Way to go Gene, looks like you need some air. :HappyMugs
How accurate do you think that dyno was, never heard of a Clayton before.
nice #'s
CLAYTON DYNO
GENE
:confused: Gene, shouldn't the 639 run have had a higher torque number?
Or am I missing something here?
--Scott
--Scott
I was thinking of the same thing. good numbers Gene.:Thumbup:
--Scott
It was obviously that HP at a higher RPM.
Let see if I can get this right.
639(hp) = ?(RPM) x 985(tq) / 5252 =
639 = (X) (.18754) =
X = 639 / .18754 =
X(rpms) = 3407.27
As opposed to the 573hp 918tq run which would be:
573 = (RPM) x 918 / 5252 =
573 = (RPM) (.17479) =
(RPM) = 573 / .17479 =
RPMs = 3278.21
What I mean to illustrate by this is that the only way the 639 run would've had a higher tq number proportionally is if it was at the same or lower rpms proportionally.
Was that the RPMs Gene, or did I make a total booboo somewhere?
X = 639 / .18754 =
X(rpms) = 3407.27
RPMs = 3278.21
yep, that makes sense....(If that is the explanation, that is)
Thanks for writing that out Loco, I didn't get out my formulas to do the calculations....:Thumbup:
X = 639 / .18754 =
X(rpms) = 3407.27
RPMs = 3278.21
The RPM's were 3613 on the 639 run and 3604 on the 573 run.
You were close , the reason for the low RPM's is we had the program in for the drag strip which shifts lower to go faster. It sounds strange but it works for us.
GENE
Sounds strange? Aren't you just staying in the engine's power curver better?
Gene, given the hp formula, there's no way this can be, please explain.
I'm not questioning you, just trying to learn.
Is it the error margin of the dyno or tach, both?
Discussion Starter #15
Don't have a scanner here
They just captured 4th gear , as we forgot to get the dyno tune to lock out 5th gear. Not sure how well that works but thats all we could do.
GENE
Got Torque?
Could it be affected by the timing of the nitrous shots? Because from Gene's post, the peak power came at almost exactly the same RPM, which tells me something is off somewhere. The HP to torque formula does not change, but something is weird here. I would have expected north of 1100 ft pounds.
RL
1 - 16 of 16 Posts
