My marker lights are out in front... the ones in the little triangle next to the headlight.
What's the easiest way of getting at them?
:sofa:
IIRC the assembly should pull straight out--be careful, since they're usually pretty snug but if you pull hard enough, they'll come out.
I think there are a couple of screws holding them in place.
Maybe I'm mistaken. I haven't looked lately.
prt
You're right--I forgot--there are two Phillips-head screws at the bottom of the marker assembly. It might be easier to loosen the bumper and drop it down an inch or so to get at them since the space to access them is kind of snug.
I had to loosen my bumper when I put my smoked turn signals in.
FYI, there are no lights in the triangle portion of the lights, only the lower square part next to the turn signal portion.
Discussion Starter #6 (Edited)
Thanks for the replies, I just went out and took them off and there is NO bulb in the triangle. Shame on me!
Otherwise thanks, Wednesday I am swapping out the ugly XL glass lights with the next step up that all you guys take off. :haha
