I've got a Superchips Micro tuner 2001 (94-02 7.3L PSD retail version1700) for the 97 F250.
Now the PSD is stock except for a TYMAR intake & the fuel pressure regulator shim.
No gauges & stock downpipe and exhaust.
Went to re install the program and I can't find the instructions anyplace:shrug:
Anywhoo, I thought it had a couple of diferent programs, but it just asked if I wanted to install the off road program & I said no.
Then it asked something about a top end speed & I said no.
Expected it to come up and ask what HP, but it never did.
How can I find out what tune program it installed, the one I was running (installed several years ago) as far as I can remember was a mild one since I've got the stock downpipe and no gauges.
Fire Extinguisher Inside
RampRat said:
Iit just asked if I wanted to install the off road program & I said no.
Evidently you all ready have the tow safe mode installed. Which I believe is the 40 HP setting on a 97. It should also have given you the option to return to stock.
Off road is 60 (I think)
Shouldn't need the instructions. It pretty much tells you what to do next once its plugged in.
