· Junior Member
ive picked up a cheap 12 vlave to start on my swap:rock:happydance so now i need to figure out what i need for running the nv4500 or 5600.im still running my ford manual transfer case so i know ill need the to repalce the input shaft and obviously a new clutch and brake pedal but what else do i need to run the dodge nv?i found south bend sells the whole upgraded clutch resivior which im sure ill need.i also know i have to cut a hole for the shifter but do i have to cut the whole trans tunnel out or just put a hole for the shifter?ive got the 5r110 but since it would be way more expensive and a nightmare to tune it right i want to go to a manual that way ill have the right reliable trans for upping the power and it wont have to hunt for the gears in an auto.
