Hello, I am looking for information for my 2005 F750. I am building it into a pickup truck. It was previously started by the original owner. It has a bed on it already. I would like to lift the suspension as the front stock might looks to low in comparison to the rear. If I put the rear axle below the leafs in the rear I will gain 9". Then I can have from leafs made to raise the front 9". The only problem I haven't figured out is the drag link is going to need a offset for the pitman to steering arm connection. Can I just lengthen and make a offset draglink, or is there a other option? Will a offset draglink work properly? Any info would be great.Thanks.
