Hello all,i am a new member to the forum,i am working on 4700-T444E engine,1998 model.when the engine is cranking is bringing slight white smoke from silenser and refuse to start,but if i use fluid to start it,it will respond almost to start but it won't start,scan for code and i got #1(PID 108 BAROMETRIC PRESSURE FMI4 VOLTAGE BELOW NORMAR OR SHORTED TO LOW VOLTAGE ACTIVE FAULT)#2(SID 254 CONTROLLER #1FMI8 ABNORMAL FREQUENCE,PULSE WIDTH OR PERIOD ACVTIVE FAULT),which componet that is gone bad indicating the code,can this code preventing the engine from starting?where in the engine i can fine the bad component causing above code,any help will be greatly appreciated..
