OASIS RESULT:
1FMNU42F43EB25301
05/23/2007
21:32:17
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 EXCURSION BODY STYLE
LIMITED 4 DR 4X2 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
C1 ENGINE CALIBRATION
2L119Y0A
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
BEFORE REPLACING DIESEL HIGH PRESSURE PUMP (-9A543-) SEE TSB 04-04-04
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
11/12/2003 BUILD DATE
10/31/2002 SALE MILEAGE
00189
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
06/12/2006
DEALER: Duval Ford
WARRANTY CLAIM NUMBER: 007445 ODOMETER: 053235M
LABOR OP
CONDITION CODE
CONDITION DESC
2C3Z 9G804AB O-RING KIT 001 040404A D8 FAILED GASKET/SEAL
OSP 003 6007D
CK OUT, VERIFY CONCERN. FOUND ENG LEAKING OIL. CK OASIS #113394802, FOUND TS B 04-04-04. HP OIL PUMP FITTING LEAKING. PUT OIL DYE INTO ENG. USING BLACK L IGHT FOUND THAT THE HP OIL PUMP FITTINGS WERE LEAKING. REMOVE OIL LINES. REM OVE FITTINGS. REPLACE O-RINGS AND PUT TOGETHER. CLEAN OFF ENG. LET ENG RUN. NO OTHER LEAKS FOUND AT THIS TIME. 53235
END OF OASIS REPORT FOR 1FMNU42F43EB25301
